Watching Cricket on BELL HELP!
Username: Afaizi
Post Number: 36
I found out that Bell ExpressVu is showing the Pak vs. India match on channel 703. I for some reason can't get this channel. Can someone tell me whether this channel is on 91W or 82W and also what satellite should I scan?
Username: Cricpower
Post Number: 37
hey Afaizi, the channels is on 91W but for some reason it only works during the match time. You need to do a blind scan just when the match is about to start..After the match was over, the channel says scrambled channel for some reason
