Head units??
Username: M0nkeyman692
Post Number: 384
so one of my friends was talking to someone from crutchfield and the person told him that it is not necessary for ford explorers to have to get a new head unit. and the guy said you can plug in subs to the stock HU... i told my friend the guy was wrong because in order to hook up subs you need a rca output on the HU.. my friend is convinced hes gna hook up subs to his stock explorer head unit.. so im just checking so i dont look retarded..
on all ford explorers ive seen there is no rca output in the stock HUs so is it possible too hook up subs without it?
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 1...
Post Number: 5448
They prolly told him he could use a LOC or OEM interface and he misunderstood.
Username: 30hrtz
Raleigh, Nc U.s.a
Post Number: 108
lots of amps,including kicker,will take speaker wires spliced into rear spekers in vehicle as an input,instead of rcs's.my rca output went bad on my deck and i did that on my kx600.worked fine...not as good as rca's but o.k.
Username: Nd4spd18
Northwest PA
Post Number: 3688
You can use an amp with line level inputs or use an LOC. But SQ will suffer unless you get a real HU.
