Chancysand200t not autorolling anymore
Username: Bomberman
Post Number: 24
it's not doing it with me for dish network atleast. all i get is something like waiting for keys to roll or a similar message like that i can't remember, but it never goes to waiting for picture so it never reaches this to start the process, is it working for anyone else?
Username: Viruscauser
Leesburg, Georgia
Post Number: 344
It sometimes does that and I dont know why. I do know it's not really looking for keys. What you can do is move to another channel and move back and all should be ok.
If it's a real problem, re-flash your receiver with the jvvh_220 bin or the other jvvh_jeep_220 bin if you can find them at FTABINS. In my experience, every box is different and some bins work better than others depending on the box.
Username: Majikone
Post Number: 15
Mine also gave Wait for pictures , but I changed the channel and waited, it worked.
It's the same old problem when switching between Bev and DN, Dn get lost.
I have to take it to echo 3 then to echo 7 or 8.6.
Username: Kacha
Post Number: 8
i just downloaded the chancy 220 bin and when i tried to scan nimiq1 it gives me a blank screen and restarts the box. someone help!!!!!
Username: Koko_wawa
Post Number: 50
Turn your receiver off from the back switch then on and the auoroll should work.
