Quality Signal Strength - how to achieve
Username: Leoaug2007
Post Number: 7
My quality signal strength is keep changing and i am losing the channels frequently. can someone suggest how to get around this situation.
Thanks
Username: Donnie1973
Post Number: 1663
ur dish may by out of line. Maybe rain or high winds?
Username: Rtap
FL
Post Number: 875
need more info to help.what stb,bin flie.
Username: Rtap
FL
Post Number: 876
peter if your signal keep giving u problems check your stb.follow this link.
https://www.ecoustics.com/electronics/forum/home-video/400114.html
good luck
Post Number: 8
Thanks a bunch, RTAP i will sure try this procedure.
Username: Bobcunk
my signal is 70% but theres a tree in front. right now it s cutting out but there is supposed to be a storm coming so i think its clouds usualy when my tv does this it starts to rain.
