OK you experts what should I buy?
Username: Igor_xxx
OK all of you experts here tell me what amp in your opinion should I buy
http://www.sonicelectronix.com/item_8570_Kenwood+KAC-8103D.html
http://www.sonicelectronix.com/item_8522_Pioneer+GM-5300T.html
http://www.sonicelectronix.com/item_8514_Kenwood+KAC-7203.html
http://www.crutchfield.com/App/Product/Item/Main.aspx?i=113KAC7201&tp=115&tab=fe atures_and_specs
so guys i plan to run the amp bridged so i dont need the 2 channels and i am on a very low budget and theese are the only options for me.please help
Username: Drant19
TX
Post Number: 43
1. what are you trying to power?
2. what is the final ohm you need the power at?
Username: Nd4spd18
Northwest PA
Post Number: 3595
None of those amps are good. Kenwood sucks and Pioneer are so-so.
And if you're powering a sub get a class D amp not a 2 channel amp.
Username: Igor_xxx
Post Number: 8
What I will be powering is in a debate in the subwoofer forum but it wil be propably pioneer ts-w307 at 4 or 2ohm or kenwood kfc-3011 at 4ohm
Username: 420alldaylong
Post Number: 2845
Whats budget for amp and sub?
What size sub?
Username: Igor_xxx
Post Number: 9
For the amp 150$ and for the sub 100-150$
the sub can be 10 or 12'
Username: Igor_xxx
Post Number: 11
And I forget to ask, what do you think about Blaupunkt amps and subs?are they good?
Username: Nd4spd18
Northwest PA
Post Number: 3617
Nope
Since your limited to specific brands, look for a mono Pioneer amp.
Username: Igor_xxx
Post Number: 13
OK guys from opinions i understanded that i need class D monoblock amp because i plann to run 1 sub.
can somebody tell me what do you think about sony xplod because i saw this in a local store and it wasn't very expensive, around 130$
http://www.sonicelectronix.com/item_5027_Sony+XM-SD61X.html#
Username: Drant19
TX
Post Number: 46
sony = cheap...get the pioneer sub. i have 2 of the older models and they sound good. if you get the dual4ohm model then get a mono amp that puts out about 300-500rms in 2 ohms
Username: Nd4spd18
Northwest PA
Post Number: 3629
Sony is one of the absolute worst brands in car audio
Username: Igor_xxx
Post Number: 14
that's good to know.so can you make your sugestions which amp should i get?i dont know should i take the kenwood kac-8103d because i heard it today in a local shop with kenwood kfc-w3514dvc at 2ohm and let me tell you it really shaked the windows at the store and the amp+sub=300$.i mean for that price can i ask for more.
Username: Nd4spd18
Northwest PA
Post Number: 3640
Kenwood's quality is complete crap, they fail within 1 year or so of use usually
List all the brands you have access to for amps and I'll tell you which ones are wother considering
Username: Drant19
TX
Post Number: 51
wheres that good/bad list that shows all the brands?
Username: Nd4spd18
Northwest PA
Post Number: 3643
https://www.ecoustics.com/electronics/products/articles/329117.html
Username: Igor_xxx
Post Number: 15
Most availible brands here are JBL,kenwood,pioneer,alpine,sony,blaupunkt(the GTA series) but alpine and JBl are above 200$ so my only choice is pioneer or kenwood for the money and the power.i can get JBL or Alpine but they wont be very powerful beacuse of the money i have
Username: Igor_xxx
Post Number: 16
here is one good site at my place
www.autoland.com.mk
tell me what you think
Username: Nd4spd18
Northwest PA
Post Number: 3655
JBL, Alpine = good
Pioneer = ok
Kenwood, Sony, Blaupunkt = bad
Username: Igor_xxx
Post Number: 17
OK, I need this opinion from you guys.What would you buy, a quality amp and sub but not very powerful (around 150-200rms) or something like kenwood and the others cheap amps and subs but powerful(300-500rms)?because this is my current situation and honetsly I dont know what to do.will the quality ones be better then the others(the cheaper)?
Username: Nd4spd18
Northwest PA
Post Number: 3659
If you buy a low quality amp there's a good chance it will blow within a year or so of use, then you'll be paying more to replace it than if you bought something good to begin with.
So buy something good. I would recommend saving more money until you can get something with decent power though.
Username: Igor_xxx
Post Number: 18
Yeah you are right I will wait one or two months and buy something more powerful from JBL or Alpine but what can you tell me about the sound quality of the JBL subs and are they worth the money?
Username: Nd4spd18
Northwest PA
Post Number: 3676
JBL subs are good. The only ones I've actually heard are the GTIs and they sounded very good.
Username: Igor_xxx
Post Number: 19
Thanks guys very much for the help and that you told me not to waist my money on something like kenwood and the others cheap amps and subs.I will by something from the JBL GTO series.thanks
Username: Nd4spd18
Northwest PA
Post Number: 3715
No problem man....... when you do get a system together make sure to post it
Username: Igor_xxx
Post Number: 20
when I get my system I post it at the same time and tell you how it sound.thanks
