New member Username: AudiosaabPost Number: 1 Registered: Nov-07 | Hey guys, i'm here to ask a quick question for whoever is willing to help...Im currently selling my current subwoofers and purchasing a sealed fiberglass enclosure from tccustomsaudio.com to hold 2 12" Alpine Type R Subwoofers. I was wondering what type of amp i should use to pump these subwoofers to full capacity without them blowing out, what capacitor would be good to get if im looking to buy one, and if anyone has used tccustomsaudio.com before and if they r trustworthy....also should i get a ported box? or sealed.... please help, any would be appreciated thanks! |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3674 Registered: Jul-06 | Ported box. If you tune it right it will sound as good as a sealed and be louder. No capacitor, they don't help. Haven't used that site. Amp, you will need a 1000 watt RMS amp, make a thread in the amp section if you need to know which ones are good. |
Silver Member Username: Spivey17323Dunellen, New jersey United states Post Number: 820 Registered: Jun-07 | dual 2 or dual 4?? and what are you looking to spend? |
New member Username: AudiosaabPost Number: 6 Registered: Nov-07 | wouldent the capcitor help with the lighting problem where everything dims, i already understand how it dosent really save battery power but im looking to fix the dim that i currently have with lesser subwoofers..would dual 2 or dual 4 hit harder? im thinking dual 4 right now and M.S thanks for the 1000RMS reccomendation....is there any site you know of to get a ported or vented fiberglass box? |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 5612 Registered: Jul-06 | There are lots of people that build custom boxes with fiberglass but they will cost you a good buck.Contact BJ Fisher of Fisher Customs(Google his name) or you can try Woodlawn Cabinetry,you can make a thread about the box and someone will probably help you out. |
New member Username: AudiosaabPost Number: 10 Registered: Nov-07 | yeah the current price im spending for the fiberglass box (finished) is $300 off this tccustoms.com site it holds 2 12" subs but im not sure whether or not to trust the site... and thanks for the advice |
Silver Member Username: Hurricanebr1anWestern Burbs of Chicago, IL Usa Post Number: 206 Registered: Sep-07 | dual 2 or dual 4 referred to impedence of the subs. josh was trying to help u out with an amp. if u havent bought the subs yet, then u will need to decide, as alpine makes either config. |
Bronze Member Username: AudiosaabPost Number: 12 Registered: Nov-07 | dual 4 and their already purchased, my friend works at best buys so hes got them already for me... there is always returns though if they are not what im looking for for a good amount of base |
Silver Member Username: Hurricanebr1anWestern Burbs of Chicago, IL Usa Post Number: 207 Registered: Sep-07 | d4s so you need an amp that run 1000wrms at 1 ohm. budget for amp? and try fishercustoms for the box. He will give u a straight up shipped price and is recommended by everyone here |
Bronze Member Username: AudiosaabPost Number: 14 Registered: Nov-07 | alright thanks man, i just emailed him so well see what he says about it... so i can run both type R 4ohm subwoofers off of a single amplifier? and i dont have a real budget for an amp so any suggestions r fine |
Bronze Member Username: AudiosaabPost Number: 19 Registered: Nov-07 | anyone else got ne help for me on this whole setup i got going? |
Silver Member Username: Kyle_lowePost Number: 624 Registered: Apr-06 | amp http://www.sundownaudio.com/ sae1000d |
Gold Member Username: CarguyPost Number: 6573 Registered: Nov-04 | You can run 1, 2, 3, 4, 5, 6 subs off of one amp as long as you meet the ohm requirement. Look at MTX/Xtant/RF/Kicker/PPI/Orion class D amps. If you're wanting to install a cap, use 1F for every 1000w of peak power. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3680 Registered: Jul-06 | The lights usually will dim a little when the bass hits. But if your voltage is dropping, the only way to fix that is an HO alternator. And before you ask, no a battery will not fix it either. HO alt if you getting voltage drop. No 2 ways about it. |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 6844 Registered: Jul-06 | http://www.glasswolf.net/caraudio/charging.html http://www.glasswolf.net/caraudio/capacitors.html good reads about charging systems/caps....shold clear some stuff up i second the sundown 1000d....also second what isaac said |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3682 Registered: Jul-06 | ^^^^^^ That's real good info And those amp brands are all good except MTX. |
Silver Member Username: CharlesbhsDallas, Tx USA Post Number: 309 Registered: Jan-07 | i have a JBL BP 1200.1 that i was gonna give to a friend but it does a rated 1200rms at 1 ohm and i heard the amps are underated. just if your interested. i'll give you a good price. |
Bronze Member Username: AudiosaabPost Number: 21 Registered: Nov-07 | thanks guys you guys are helpin this along very nicly btw are soundstream subwoofers any good? also if i was to get a capacitor is "power acousik" crappy? |
Bronze Member Username: AudiosaabPotomac, MD Post Number: 22 Registered: Nov-07 | oh and to top that<---sorry for all the questions lol trying to figure this out...does anyone know where to get the Pioneer DEH-960MP Decks? cause im looking to purchase one but cant find the premier series anywhere... |
Silver Member Username: Spivey17323Dunellen, New jersey United states Post Number: 822 Registered: Jun-07 | i used to have 2 d4 type r's... massive p1000 worked great for me. |
