Username: Mattlayne Post Number: 35 Registered: Jun-06
Sunday, November 04, 2007 - 16:45 GMT my USB flash stick is not working for me to upload a new bin. will any flash stick work? i was gonna go to radioshack and buy one, but wanted to make sure it would work first...any help is appreciated...thanks
Username: Lklives Post Number: 13390 Registered: Jan-06
Sunday, November 04, 2007 - 16:47 GMT U must format it first..most all will work
Username: Mattlayne Post Number: 36 Registered: Jun-06
Sunday, November 04, 2007 - 16:48 GMT thanks a lot LK.....
Username: Mattlayne Post Number: 37 Registered: Jun-06
Sunday, November 04, 2007 - 16:50 GMT i am new with the USB......but how do i go about formatting it? do i do it with the receiver or my pc?
Username: Mattlayne Post Number: 38 Registered: Jun-06
Sunday, November 04, 2007 - 16:59 GMT hello please help...
Username: Dimwitt Post Number: 174 Registered: Aug-06
Sunday, November 04, 2007 - 17:01 GMT put in recever with the main power switch off. turn on stb with switch and it will format the usb. code and channel folder. take usb to computer find the bin file and drag it to the usb code folder bring usb back to stb and update the stb
Username: Mattlayne Post Number: 39 Registered: Jun-06
Sunday, November 04, 2007 - 17:11 GMT I just tried doing that with my old flashstick but it did not work.....but i probably need a new flashstick anyway......will try the new one later....i do have to go to format usb in the menu options do i?
Username: Dimwitt Post Number: 175 Registered: Aug-06
Sunday, November 04, 2007 - 17:21 GMT receiver will format the usb have the main power off, insert usb , turn on with the switch, stb will reboot and format the usb
Username: Mattlayne Post Number: 40 Registered: Jun-06
Sunday, November 04, 2007 - 17:25 GMT thanks a lot really appreciate it.....will try it..
