Username: Borikengirl Post Number: 1 Registered: Nov-07
Friday, November 02, 2007 - 14:02 GMT After downloading the new file all i get is "No Signal" On Antenna Setup...Level 99% but Quality 0....on Echo 119 and Echo 110 Please help....
Username: Dr_dss Post Number: 220 Registered: Sep-07
Friday, November 02, 2007 - 14:08 GMT Go into Antenna Setup reconfigure you switch port information.
Username: Borikengirl Post Number: 2 Registered: Nov-07
Friday, November 02, 2007 - 14:19 GMT I'm sorry I am completly new @ all this... I don't see that on Antenna Setup...
Username: Dr_dss Post Number: 225 Registered: Sep-07
Friday, November 02, 2007 - 14:25 GMT goto menu/ installation/ Antenna then check diseqc settings on 110 119
Username: Borikengirl Post Number: 3 Registered: Nov-07
Friday, November 02, 2007 - 14:41 GMT Tried Diseqc 1..2..3..4 and nothing changes... Thank you very much for your help....
Username: Rtap FL
Post Number: 860 Registered: Jan-07
Friday, November 02, 2007 - 14:45 GMT oye borikual what dish are you using.
Username: Borikengirl Post Number: 4 Registered: Nov-07
Friday, November 02, 2007 - 14:52 GMT Dish 500
Username: Rtap FL
Post Number: 864 Registered: Jan-07
Friday, November 02, 2007 - 14:55 GMT does it look like this.
Username: Borikengirl Post Number: 5 Registered: Nov-07
Friday, November 02, 2007 - 15:01 GMT Well I can see the antenna and it says Dish 500...other than that....I don't know...
Username: Laurad Post Number: 37 Registered: Aug-07
Friday, November 02, 2007 - 15:32 GMT Help. I have successfully changed my 2500A to 2700. I loaded the jvv218 bin, I put keys in manually with key-code on DN off BV off and GLOBAL off. I have Echo 11 and 119 along with Nimq(1)(91 levels are 79% quality 90%. checked Antena settings DisEqu is #2.I still keep getting channels going to percent 350 and above. I still have no picture except info channel and cannot find my Echo anything..Please Advise LauraD did not kill (2nd) Pansat
Username: Borikengirl Post Number: 10 Registered: Nov-07
Friday, November 02, 2007 - 20:29 GMT Pansat is still showing "No Signal" I have dish 500... Echo 119 is on LNB Type..........Dish Pro LNB LOcal FReq... 11250 22khz .......... Off Diseqc............#1 Legacy SW ....... None Skew ............ 45 TP .......... (17) 12457 V 20.000 POsitiones Setting ....Disable Satellite Scan .... All Level ......... 99% Quality......... 0%
