Viewsat xtreame. File load problem
Username: Ptaha
Post Number: 11
Hi there.
I had connected my VS to the serial port... Started the loader found the file and pc to stb option...
This took me to the window that said something something sending and nothing happened:-(
What's wrong? please help:-)
P.S. Got all the files from totalfta.com
Username: Saqeeb9000
Post Number: 42
have u ever tried loading the file before from totalfta.com?
or is it ur first time.
u have to turn of ur reciever from back and when it says sending just turn it on from back..
it should work..
double check connection + right file for right reciver...
Username: Ptaha
Post Number: 12
first time i'm trying to do this.. can you please give me the links for the correct file?
please?
thx
Username: Donnie1973
Post Number: 1581
totalfta.c0m
new files right on the front page.
U may need to copy/paste that zmodem file in to ur system folder on the c drive.
Also, where did u get the cable?
Where did u get the loader? Whats the name of the loader program?
Username: Ptaha
Post Number: 13
the guy who installed the thing gave me cable...
the loader from fta asked for a link
loader 2 was the name I think...
Can u please give ma a link to files/loader so I can a correct one if possible
HELP is APPRECIATED:-)
Post Number: 1588
totalfta.c0m has it on the main page
Username: Guanajuatos_best
Post Number: 93
YO SON
TRY TO UNZIP THE FILE:-)
Post Number: 1602
ahhh, the simple things....
Sometimes u forget not everyone uses a pc much.
my money is on that paisa
Username: Timscarlet
Usa
Post Number: 262
viewsats need to be turned off first, load loader, press pc to stb, turn on viewsat in back, this will start load
Post Number: 1604
sada said that earlier. There is a great pdf file with pics at total. It comes with the loader 2 zip file.
