9515
Username: Shade
Moxee, Wa U.S.
Post Number: 432
well i just purchased a 9515, and it should be here next week. i need a box design that will fit into my neon. to fit past my trunk opening it can't be any taller then 16 inch's....is that gonna be hard to design? i have a prefab sealed in my garage that i'll use temp. but i def. wanna do ported
Username: Skibum12189
Cleveland
Post Number: 1944
you'd would be kicking DD in the balls putting the 9515 in a sealed box....
but anyways...i really i have no idea how to design a ported box for ya...hope that helps!
Username: Shade
Moxee, Wa U.S.
Post Number: 433
lol it does. well i still have my type r's in a tcab but u know how it goes, u get anxious.
Username: Nd4spd18
Northwest PA
Post Number: 3574
Congrats on the purchase, I have that same sub and it's the best one I've ever owned.
I would NOT put that in a prefab sealed box though. You don't realize how powerful that sub is until you play it. It could very easily blow apart that box.
Username: Shade
Moxee, Wa U.S.
Post Number: 434
that'd be cool LOL
perhaps a future video if i can figure out how to convert them from my moto Q
Username: Somedonniedude
Post Number: 332
Box blowing FTW!!
Username: Nd4spd18
Northwest PA
Post Number: 3576
That would definetly not be cool when you damage you're subs suspension due to playing with no air resistance from a blown box.
Username: Rovin
4 10 Pioneer...
Post Number: 12446
seeems like u leapt b4 looking - u should be aware most 15s need around 4cuft of volume to perform well ......
Username: 420alldaylong
Post Number: 2832
4.8cf after dislpacement of sub/vent
64sq. in. vent 16"long tuned around 40HZ
Username: Rovin
4 10 Pioneer...
Post Number: 12448
^^what u suggest for a 9512 then ? .....
Username: Th3pwn3r
Post Number:...
Post Number: 5501
Take out your rear seat and slide the box in from the cabin of the vehicle into the trunk.
Username: Frkkevin
Post Number: 3959
^^ .. measure your trunk opening if you took the seat out, thats how i had to install my box for my 15"s .. you can get 4+ cu.ft with a 16" high box.. but its a tight fit for the sub
Username: Shade
Moxee, Wa U.S.
Post Number: 436
i'll measure today, if mark potts website was up i could just look there since i had to measure for that tcab which takes up my whole trunk
Username: Shade
Moxee, Wa U.S.
Post Number: 448
lol so now i measured
dunno how measurements are supposed to go but here goes(going off the tcab that's in there):
14.5 tall x 26" long x 26" wide
sufficient room for the 9515?
Username: Th3pwn3r
Post Number:...
Post Number: 5541
Well if you have a 15'' sub unless you plan on mounting it in a shallow box it's not going to work or you'll have to go with some other crazy design.
Username: Shade
Moxee, Wa U.S.
Post Number: 449
ok so work with me, i'm still learning, seems i learn something new every day. how do i determine how much cu feet that is?
that's just the current box in there, my trunk is taller then that by about 6inches but if i'm going throu the trunk latch or w/e , the max. i can get in was 16inches, haven't take my back seat out yet to see what i can there
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1803
good buy on the sub...ive got a 9515 and it gets really fu<kin loud and i think it sounds better then my old sd2.5's...just alot louder
it does need a big box to sound good though
Username: Johnfiac
A-ToWn, 9515 thumpin... What u bumpin?
Post Number: 3726
"You don't realize how powerful that sub is until you play it. It could very easily blow apart that box."
I blew apart a ported box with 1 9515F..... that was the end of it in the cadi trunk.....
Username: Shade
Moxee, Wa U.S.
Post Number: 450
anyone got AIM, i'm curious about what i can do to fit this in my trunk...
Username: Shade
Moxee, Wa U.S.
Post Number: 451
truellyshaded = AIM
Username: Snarl2004
Post Number: 1804
snarl2004
Username: Johnfiac
Post Number: 3728
your best chance is sub firing up in a shallow ported box
Username: Shade
Moxee, Wa U.S.
Post Number: 452
well i kinda wanna fire aero's if possible, into my 6x9 holes in the rear deck....i don't know anything about box building but am trying to learn
Username: Rovin
4 10 Pioneer...
Post Number: 12458
14.5 tall x 26" long x 26" wide ''''
using 3\4 mdf that about 4.52cuft b4 sub & port displacement
should be ok if ur using aeroports since those take up less space than slotports ....
Username: Rovin
4 10 Pioneer...
Post Number: 12459
Username: Johnfiac
Post Number: 3732
Dbl post FTL
Username: Jesse59672
OKLAHOMA
Post Number: 744
soundpressure.com ftw
