Username: Chicky3884 USA
Post Number: 99 Registered: Aug-07
Saturday, November 24, 2007 - 18:55 GMT Im just wondering if the bins are the same for the pansat 3500s as the 3500sd?
Post Number: 100 Registered: Aug-07
Saturday, November 24, 2007 - 18:58 GMT and what do I do once the bin is done downloading? do I have to set up my reciever again or anything?
Username: Rtap FL
Post Number: 1141 Registered: Jan-07
Saturday, November 24, 2007 - 19:03 GMT hey chick yes they use the same files.just scan your birds(echo7,8)wait till keys roll and watch tv.the current file is 339.good luck
Post Number: 101 Registered: Aug-07
Saturday, November 24, 2007 - 19:07 GMT Thank you ,thank you ,thank you!! I spent 3 days trying to do this last week and finally someone at fta told me I was using the wrong cable I had a straight through or something so I had to order the null modem cable but I think I got this now!!! LOL Hopefully!
Username: Rtap FL
Post Number: 1143 Registered: Jan-07
Saturday, November 24, 2007 - 19:15 GMT A Ariza Ultra 400 - Null Ariza Ultra 500 - Null Ariza 700 - Null Ariza 750 - Null Ariza Extreme - Null Astrovox 2600 - Straight DB9 B Blackbird and ALL Blackbird CLONES - Null BlueJay2 - Null Buzz S2010F - Null Buzz S2010F Plus - Null Buzz S2020F - Null C Captain 7000 Premium - Null Captian 8000HD - Null Captain 9000DVR - Null CaptiveWorks 100R PVR Unit - Null & USB CaptiveWorks 500S - Null CaptiveWorks 600S - Null CaptiveWorks 600 Premium - Null CaptiveWorks 1000 - Null & USB & ETHERNET CaptiveWorks 3000HD - USB & ETHERNET Conaxsat CNX-V1 - Null & USB Conaxsat Duo - Null & USB Conaxsat Trio - Null & USB Coolsats 4000 Plus - Null Coolsats 4000 Pro - Straight DB9 Coolsats 5000 - Straight DB9 Coolsats 6000 - Straight DB9 Coolsats 7000 PVR - Straight DB9 & USB Coolsats 8000HD - Null Coolsats 8100HD - Null Cooltec - Straight DB9 Coship (All) - Null D DGStation Mutant 200S - Null DGStation Relook 400S - Null DGStation Relook 300SV - Null Digiwave 5900C - Null Digiwave 6800 - Null Digiwave 7000 - Null Digiwave 7200S - Null Digiwave Diamond - Straight DB9 Dreambox (All) - Null E Eagle Star 2500A - Straight DB9 Ebox Mimic (Viewsat Clone) - Null Extremeview Magnum XV3300 - Null F Fortec 5000v2 - Null Fortec 5100 Diamond - Straight DB9 Fortec 5100 Plus - Straight DB9 Fortec 5100 Plus+ - Straight DB9 Fortec 5100 Ultra - Straight DB9 Fortec 5400 NA - Null Fortec 5400 - Null Fortec 5600 Plus - Straight DB9 Fortec 5600 Ultra - Straight DB9 Fortec 5600v2 - Null Fortec ALPHA - Null Fortec BETA - Null Fortec LIFETIME - Straight DB9 Fortec Lifetime Classic NA - Null Fortec Lifetime Classic - Null Fortec Lifetime Diamond - Straight DB9 Fortec Lifetime ULTRA - Straight DB9 Fortec Lifetime Ultra Diamond - Straight DB9 Fortec MAGIC - Straight DB9 Fortec MERCURY II - Null Fortec Platinum NA - Null Fortec PLATINUM - Null Fortec Ultimate - Straight DB9 L Lava 2600 - Null Lava 3200 - Straight DB9 Lava 3500 - Null M Max 2500 - Null Megasat (All) - Straight DB9 Microroyal (All) - Null Mvidea FS 4000 - Null N Neosat Lite - Straight DB9 Neosat Lite Premier - Straight DB9 Neosat iPro1000 - Null & ETHERNET Neosat iPro2000 - Null Neusat SP6000 - Null & USB Neusat SP6000 Premium - Null & USB Neusat 9000HD - Null & USB NFusion Nova - Null & ETHERNET O Orasat V3 - Null Orasat V5 - Null P Pansat 200A - Null Pansat 250SM - Null Pansat 300A - Null Pansat 330A - Null Pansat 500 CI - Null Pansat 700H - Null Pansat 1500a - Straight DB9 Pansat 2000V - Null Pansat 2300a - Straight DB9 Pansat 2500a and ALL 2500 CLONES - Straight DB9 Pansat 2700A/E and MOST 2700 CLONES - Null Pansat 3500S - Null Pansat 3500SD - Null & SD CARD Pansat 5000HC - Null & USB Pansat 6000HXC PVR - Null & USB Pansat 9000HD - Null & USB Pantec/Multistar Max (All) - Null Pantec/Multistar MS (All except MS1000) - Straight DB9 Pantec MX/Ultra - Straight DB9 R Rex1 - Null S SatCruiser - Null Satopia ST1100-UT - Null SatPros DSR500 - Null Silver Bullet/ST 1000 - Null Silver Bullet/ST 2000 - Null Skytech 2700A - Null Skyview 500 - Straight DB9 Skyview RX600 - Null SkyView Plus SV-P1000 - Null Smartwave 2500A-N2 - Straight DB9 Smartwave 2700A-N2 - Straight DB9 Sonicview SV-1000 - Null SonicView SV1000 PVR - Null & USB Sonicview SV-4000 - Null & USB SonicView SV-8000HD - Null & USB Sonicsat Koolsat - Null Spacestar DVB500 - Null Stealth 2000a - Null T Technosat 1010 Plus - Null Techsat - Null Traxis DBS 1500 - Straight DB9 Traxis DBS 2500 - Straight DB9 Traxis DBS 3500 - Straight DB9 Traxis DBS 4500 - Straight DB9 Traxis DBS 4550 - Straight DB9 Trimax T100 - Straight DB9 U Ultrastar 5000 - Null V Viewsat VS2000 Lite - Null Viewsat VS2000 Platinum - Null Viewsat VS2000 Extreme - Null Viewsat VS2000 Ultra - Null & USB Viewsat VSPro - Null & USB Visionsat IV200 - Straight DB9 Visionsat IV300 - Straight DB9 Vortex 2700 - Null Vortex 3500 - Null Vortex 7700 - Straight DB9 X Xrica X-5 - Null
Post Number: 102 Registered: Aug-07
Saturday, November 24, 2007 - 19:35 GMT ok so I downloaded 339. Before the ppv and hbos,etc were ther just scrambled. Now most of them arent even there and the ones that are dont work. I went to installation and antenna setup selected my sats and did the blind scan. Did I miss something?
Username: Dimwitt Post Number: 234 Registered: Aug-06
Saturday, November 24, 2007 - 19:48 GMT delete channels , check antenna settings and scan again.
Post Number: 103 Registered: Aug-07
Saturday, November 24, 2007 - 19:49 GMT How do I delete channels? This is the first time I ever had to mess with this other than keys.
Username: Dimwitt Post Number: 235 Registered: Aug-06
Saturday, November 24, 2007 - 19:55 GMT menu, channel edit, delete--select all
Post Number: 104 Registered: Aug-07
Saturday, November 24, 2007 - 19:55 GMT I also have no signal for 1 satellite
Username: Dimwitt Post Number: 236 Registered: Aug-06
Saturday, November 24, 2007 - 20:06 GMT check your antenna settings menu, installation ,antenna setting normally the only things to adjust is the lnb type(i use standard) and the diseqc port ( i have 119w echo7 in port 1 and 110w echo8 port 2)
