Username: Chip_la Post Number: 10 Registered: Oct-07
Wednesday, October 31, 2007 - 21:47 GMT I puy in new keys shut of autoroll and still no picture any ideas would be great. Thanks Chip
Username: Drmunna Post Number: 11 Registered: Oct-07
Wednesday, October 31, 2007 - 22:24 GMT u must have entered wrong keys,,, mine working ok,,,double check keys
Username: Bill038 Post Number: 146 Registered: Sep-06
Wednesday, October 31, 2007 - 22:27 GMT I did the same thing, triple checked the numbers and have a no audio no video coming up on the screen. Any suggestions?
Username: Silver1123 Mexico,
DF
Mexico
Post Number: 342 Registered: Jul-07
Wednesday, October 31, 2007 - 22:27 GMT Yes, you must have wrong keys. Other viewsats are working fine. check latest keys [link removed] also, turn all autoroll options off, including EPG autoroll
Username: Nydas Post Number: 4380 Registered: Jun-06
Wednesday, October 31, 2007 - 22:30 GMT Minor key morphing last day or so. Keep auto roll off. Use keys as posted DN - Provider ID 0101 Check the third number in Key 00 - it should be 24 Check the thirteenth number in Key 01 - it should be 5F
Username: Bill038 Post Number: 147 Registered: Sep-06
Wednesday, October 31, 2007 - 22:31 GMT I only have a line 00 and a line 01. Wher4e is the line 106?
Username: Vacarosie Post Number: 31 Registered: Aug-07
Wednesday, October 31, 2007 - 22:55 GMT I put the new key from B3V in Viewsat Platinum but didn't works. Need a new bin or new keys. The keys was from this morning
Username: Bassi911 Post Number: 69 Registered: Jun-06
Wednesday, October 31, 2007 - 22:57 GMT yea i put in the new keys in the viewsat plat and i changed the autoroll to off and still i get no audio and no video. My keys are correct i checked them 34 times
Username: Vacarosie Post Number: 32 Registered: Aug-07
Wednesday, October 31, 2007 - 23:24 GMT Suppose it need a new bin
DF
Mexico
Post Number: 349 Registered: Jul-07
Wednesday, October 31, 2007 - 23:30 GMT To enter keys manually, you should select the entry that contains: 1 Nagravision or Nagra 2 Ident DishNetwork 0001 or 0101, depending on the programming of your box 3. There you will find 4 boxes or lines to input keys. the 00 and 01 divided each by two To change key 106, which you shouldnt do now, you need to do the same as above: 1. Select Nagravision or Nagra 2. Ident 0006 or 0106 3. Same four lines of boxes to enter codes
DF
Mexico
Post Number: 350 Registered: Jul-07
Wednesday, October 31, 2007 - 23:31 GMT If you entered new keys and get no picture, do as adviced in other posts by Nalin, reset your box. Turn off from back switch or unplug and re plug to electric outlet
Username: Donnie1973 Post Number: 1535 Registered: May-06
Wednesday, October 31, 2007 - 23:57 GMT if u dont have picture after entering new keys. U did something wrong...
Username: Ekoneuno Post Number: 13 Registered: Nov-06
Thursday, November 01, 2007 - 00:47 GMT I need some help. I put auto roll off. I am going to Code Menu, then to Nagra and within that going to Dish. I have two options on Dish - 01 01 00 and 00 01 00. In the first series, I have codes for 00, 08,09,88 and 89. In the second series, I have codes for o8, 09, 88, 89. I am confused on which of these to update with the new keys. Please help.Thanks
Username: Donnie1973 Post Number: 1537 Registered: May-06
Thursday, November 01, 2007 - 00:51 GMT 01 01 00. the active keys are the 89 keys. Enter keys for 01 after the 89.
Username: Ekoneuno Post Number: 14 Registered: Nov-06
Thursday, November 01, 2007 - 00:55 GMT 01 01 00 For 00 I see the following B4 ED 24 E3 BC.........C8 A1 For 89 , the last 8 keys are 00. 00 01 00, I do not see 01 at all. only 08, 09, 88, 89
Username: Donnie1973 Post Number: 1539 Registered: May-06
Thursday, November 01, 2007 - 01:05 GMT right, u need 01 01 00 dont change 00 dont change 08 dont change 09 change 88 to:25 8D 8F 67 F7 5F DF 62 change 89 to :3D 7A 4D 7C E7 86 61 90
Username: Donnie1973 Post Number: 1540 Registered: May-06
Thursday, November 01, 2007 - 01:07 GMT i meant enter keys 01 in to the 88 AND 89 keys but my last post is what u need to do. make SURE u turn off autoroll
Username: Martinpraguer Bohemia
Post Number: 49 Registered: Nov-06
Thursday, November 01, 2007 - 01:40 GMT Thanks dantetn, your posted keys work. I am using "manula mode" since all FTA sites (that I've tried so far) with bin files are overloaded with traffic. Cheers
Username: Donnie1973 Post Number: 1548 Registered: May-06
Thursday, November 01, 2007 - 01:46 GMT yeah, I know pansat has released their files, but it is near impossible to get it right now... the keys are easy to input... not too terrible
Username: Bill038 Post Number: 149 Registered: Sep-06
Thursday, November 01, 2007 - 01:47 GMT LINE 08=D6 1A 24 BF EA 89 B9 29 LINE 09=3D 84 14 3A 30 8F A4 C0 LINE 88=25 8D 8F 67 F7 5F DF 62 LINE 98=3D 7A 4D 7C E7 86 61 90 These are the latest bins. Do not change anything in line 00
Username: Harchi777 Surrey,
Bc
Thursday, November 01, 2007 - 06:35 GMT by mistake i have changed 00 line and saved the changes.pl give me numbers for 00.(for viewsat)
Bc
Thursday, November 01, 2007 - 06:38 GMT or pl write me complete list for(viewsat ultra) 00 o8 09 88 89 ( all five lines) thanks
Username: Yogibaba Post Number: 5 Registered: Feb-07
Thursday, November 01, 2007 - 12:39 GMT YOU can go to Totalfta.com to get all viewsat bin.
