Bronze Member Username: ScabzKnoxville, Tn Us Post Number: 11 Registered: Oct-07 | the keys are 7 lines long on my box and the new keys are 14 lines long. Am I in the wrong place ? I have a vs platinum. thanks |
Silver Member Username: DimwittPost Number: 166 Registered: Aug-06 | C/P VIEWSAT RECEIVERS Go to Menu, Installation,Code than pick Nagra, than left key 4 times and it'll show Dish 01 01 00 and you'll have something like 00 08 09 88 98 Only change the key on 08 and 09 08 ---- F2 98 74 44 1C 65 77 D8 (substitute latest keys) 09 ---- 17 E3 E1 1D 89 4E 53 45 (substitute latest keys) after you are done exit and save then watch TV KEY 00=08 KEY 01=09 |
Silver Member Username: HshakarchiPost Number: 128 Registered: May-06 | Thanks Tooter, one correction though, each set of keys have 32 numbers: for viewsat: KEY 00 = has 32 numbers 08 = (1st 16 ) 09 = (2nd 16 ) KEY 01 = has 32 numbers 88 = (1st 16 ) 98 = (2nd 16 ) |
Silver Member Username: Silver1123Mexico, DF Mexico Post Number: 347 Registered: Jul-07 | Bins, instructions and tutorials on how to input keys manually: |
Bronze Member Username: Bassi911Post Number: 67 Registered: Jun-06 | i changed the keys and they are correct i checked them and i turned autoroll off, i have a viewsat plat, and it still doesnt work it says no audio or video. What do i do |
Bronze Member Username: ScabzKnoxville, Tn Us Post Number: 13 Registered: Oct-07 | Like I said I can only put in 7 lines and not 8 to 16. 7 meaning ( bb bb bb bb bb bb bb ) . I can only put in 7 lines of codes and no more. 7 per each 00 = 7 and 01 = 7. Total 14 but on 2 different lines. |
Gold Member Username: Donnie1973Post Number: 1569 Registered: May-06 | naw, u have 16 after 08 16 after 09 same for 88 and 89. the keys 00 go AFTER 08 AND 09 keys 01 go after 88 AND 89 |
Gold Member Username: Donnie1973Post Number: 1570 Registered: May-06 | if u dont... reboot receiver. Still no... reload factory bin, then the last bin, try again... still no? I dont have a clue. 99-100 percent of the time, problems like this are just an oversight by the user. |
Platinum Member Username: LklivesPost Number: 13314 Registered: Jan-06 | Here's how to manual input keys for ALL receivers... https://www.ecoustics.com/electronics/forum/home-video/390294.html I suggest people use the SEARCH feature here...there's tons of good info available... Enjoy! |
