Viewsat Settings
Username: Ragidy57
Post Number: 27
Adding a dish 500 what should my settings be under the echostar 8,10 and echostar 7 in the antetna settings.
Thanks
Username: Drmunna
Post Number: 7
you need to provide more info. what u mean by adding? u already have one?
Username: Ragidy57
Post Number: 29
ok i already had the viewsat extreme up and running with a direct single lnb dish. Im installing the dish 500. I need to know what the settings under the antenna setup needs to be on the 8,10 and 7. it has dish it has 119 should that hook up to the 8,10 and the 110 hook up to the 7?
Username: Ragidy57
Post Number: 30
OK delete that i got it.
But i still can not get a program guide on the 7 channels like no info, wont tell what is playing, how long is left on the movie or what movie is about. any help
Thanks
