1. Press Menu 2. Scroll Down to Parental Control, Press Enter 3. Press "i" key on remote, then enter pin number "2004" 4. Scroll down to Set Default Key, Press Enter 5. Scroll up to Nagravision, Press Enter 6. Press VOL Right twice, you will see Dish Network 7. Press CH Down once, then VOL Right Twice, you will now see Nagravision 2 displayed top left You are now at the key 00, Press CH Down once so you can edit the Key Data 8. Enter your new keys (write down the old ones to be safe) 9. Press Ok to store, then repeat with key 01 10. Press exit until you get back to tv, all channels will be available
My old bin for Ariza 700 was not working,so I downloaded the 2.93 Bin for Ariza 700.It worked fine with no ppv channels,but since yesterday it is coming as "Scramble Channel".So I manually entered the new keys 01: 25,8D.... But still it is not working.I switched my receiver and switched on.Its not working.Can someone help me plssssssss...
Please note that this file will only work for 110 & 119. File will NOT WORK for 61.5. You have to find keys from this forum change it manually every time key change occurs.
