The wining noise
Username: B3n07
Louisville, Ky USA
Post Number: 467
ok i am getting a horrible winding noise in my compents speakers could it be becuz i am useing a smaller fues in my fuse holder i went from and 80 fuse to a 50
Username: Rideredder
Cornell, IL USA
Post Number: 1038
I wouldn't think so. Check all your grounds.
Username: B3n07
Louisville, Ky USA
Post Number: 468
did there perfect i know one of my amps is drawing 52 amps and the other is drawing about 25 amps and the it only starts to make the noise when i have the subs plugged in
Username: Tblazer74
South Salem, NY USA
Post Number: 43
Sounds like bad wiring. If the wiring it old or not good quality you may get that alternator whine. If it isn't your ground, I would just get a new better wiring kit and see if that helps.
Username: Clouduz
Post Number: 227
yea, make sure your ground is not too long, scrape off any paint, check your rca's, cheaper ones tend to pick up noise if not grounded correctly. What brand of wiring did you use?
Username: Van_man
Boston South, MA
Post Number: 2977
"only starts to make the noise when i have the subs plugged in"
Re-do the sub amps ground and check replace the rcas to it.
Username: Skibum12189
Cleveland
Post Number: 1929
did you plug the rca's in on the HU while the HU was on?
Username: B3n07
Louisville, Ky USA
Post Number: 469
nope i turned the HU of before i did that why would could it cause
Username: B3n07
Louisville, Ky USA
Post Number: 470
ok well i have checked everything over again and i found that i have a sold blue wire disonected i cant figure out what it goes to and also i checked my fuse holder and i think its time for and upgrade the fuse holder is burnt black and is causeing a bad connection so i was thinking about upgradeing to and ANL fuse and fuse holder but whats a good company to go with
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5006
any reputable brand. The cheapest brand that sells decent fuses/fuse holders is audiopipe. Is the only one i can vouch for.
Kicker would be great for the budget
