Just got a new tv (center speaker question)
Username: Xfacta82
Post Number: 99
I have a center speaker that needs to be mounted above my new tv. How can i go about doing this if i want to mount it on the wall some how?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 366
I've just used some simple shelf brackets from
Home Depot. You can even get some nice pine ones for under 10 bucks. How heavy is the speaker?
Username: Xfacta82
Post Number: 100
its like 9 by 15 or something like that...pretty heavy.
Username: Huron
Post Number: 306
take a picture so we can help, and of the center
Username: Xfacta82
Post Number: 101
I dont really have the time to put the picture up, but you think I can get something that will work at a home depot?
Username: John_s
Columbus, Ohio US
Post Number: 1862
With the help of my locally owned home theater store, I got this wall bracket and it has worked well for me.
Username: John_s
Columbus, Ohio US
Post Number: 1863
The bracket is a Sanus Visionmount VMAVB-01 (black), or a VMAVS-01 (silver).
Vann's sells both.
http://www.vanns.com/shop/servlet/item/features/763040815
http://www.vanns.com/shop/servlet/item/features/763040573
Username: John_s
Columbus, Ohio US
Post Number: 1864
That speaker is a DefTech CLR 2002.
21 3/4" wide and 12" deep. 25 pounds.
Sanus claims up to 45 pounds with this bracket.
I put a piece of wood in the back of the speaker to angle it down towards the seating area.
Username: Xfacta82
Post Number: 102
Thanks for your help!
I may have to get that :-)
Username: Huron
Post Number: 307
mmmm, very sexy pic john
Username: Dmitchell
Post Number: 372
Nice setup John.... very clean. What kind of speakers are those?
Username: John_s
Columbus, Ohio US
Post Number: 1866
Thanks Angelo and David. Apologies to Seth for hijacking his thread temporarily...
The towers are Definitive Technology BP 2004, bipolar with side firing 10" woofer driven by an internal 250 watt amp. As I said above the center is DefTech CLR 2002. Surrounds are the bipolar DefTech BP2X. There's no sub. Maybe it's a happy accident with this room, but I have measured usable bass down to 30 Hz. That's good enough for me---I am not a bass freak. I listen to a lot of music and I need balance.
I know DefTech gets no respect around here among the audiophiles and that's OK. I know there's better stuff out there. I've said before that if I were made of money you'd see some big MartinLogan panels and a serious rack of amps to run them in these pictures:
http://i160.photobucket.com/albums/t171/JohnS45/cave56.jpg
http://i160.photobucket.com/albums/t171/JohnS45/cave55.jpg
http://i160.photobucket.com/albums/t171/JohnS45/cave53.jpg
Sorry Seth, back to you now.
Username: Xfacta82
Post Number: 103
John S its alright man. That is nice set-up. But how do you like that center speaker mount? Is it durable..easy to put up? }
Username: Huron
Post Number: 308
I have heard Def tech speakers matched up with other speakers more than any others speakers over the years and they never disapiont, my PF 15 sub is still going strong, I dont recommened them to people because they will most likely set them up rong, and yes If we all had more money
Username: Huron
Post Number: 309
the bracket do you need to find a stud or do you have, I forgot what they call them, flare sinkers or something
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 437
Sheetrock anchor or Toggler
Username: Xfacta82
Post Number: 104
I need those? Where can I get them?
