2 amps, one sub??
Username: 94_toy
Post Number: 80
2 of the exact same amps on one sub with dual voice coils
say i have 2 500W RMS amp ( @2ohm) and i wanna run a 1000W rms sub. Will the sub ahve to be dual 2 ohm or dual 4 ohm and how would u wire it to run at 2 ohm??
Username: Talon01
12 audioque 2.5 144.9 ..., Pa Usa
Post Number: 234
YOU NEED A DUAL 2 OHM
Username: Frkkevin
Post Number: 3958
dual 2 .. and make sure you gain match the amps or you can damage the sub
best bet is running amps you can strap, or just one 1000rms amp
Username: B3n07
Louisville, Ky USA
Post Number: 492
i have always wanted to know if there was a way to do this with out straping the amps
Username: Th3pwn3r
Post Number:...
Post Number: 5511
You can run one amp per coil but you have to make sure the outputs of the amplifiers are equal.Strapping is the only way I'd recommend putting more than one amplifier to a subwoofer.I've known people that have done it and not had set things properly on the amps and they didn't have issues so...
Username: Insearchofbass
Post Number: 6938
there is ...one way is run two crossovers with subwoofer filtering or run two amps with a passive crossover (meaning a coil) hooked up inline with the two amps...you could also do a rca with y splits but that would cut your signal bad
Username: Nd4spd18
Northwest PA
Post Number: 3580
No need for Y splitters when most amps have RCA outputs that you can patch to the other amp's RCA inputs.
Post Number: 6954
oh yeah im not used to that M.S. im still in old school amp mode haha
