Is there a fix for fortec ultra?
Username: Jaz06
Post Number: 36
Wondering if there was a fix for fortec ultra, just need 61.5 to work again, thanks.
Username: Kingusama
Post Number: 425
no fixes ... latest key up to now is posted at www.ftasolutions.blogspot.com
Username: Tscon
Post Number: 10
FIX? Where are you've been?
Read "DISHNETWORK DOWN" post.
I don't think anyone still supporting fortec ultra
since most people already convert it to Pansat 2700
Not me though I'm still using it till this day..
We'll see. Maybe I'll buy new box, not sure which one yet. Any recommendations? What is the best supported boxes? Viewsat?
Username: Ill0_ill
King there old key...
Username: Ustaad_hc
Post Number: 289
its not keys problem something else you have to wait.
Username: Ill0_ill
Post Number: 7
Check fortecfiles.com
It might help..
Username: Nydas
Post Number: 4204
There is NO fix for Fortec Ultra yet.
Username: Ill0_ill
Post Number: 13
Is there a way to convert fortec star to pansat 2700?
Username: Gonxggo
Post Number: 7
Nalin,
Do you think there will be any fix for Fortec Ultra? Or you recommend buying a new receiver? Some people suggested converting to 2700. I don't know how to do that. Is there a specific thread?
Please help.
Username: Nydas
Post Number: 4217
If DN insists on using two sets of IDs and keys, a new BIN will be needed. The BINs were created by BL a programmer knowing a lot about the BINs of Pansats. He has categorically stated that there will be no more new BINs for Pansat 2500. Future-fta.info has removed the Pansat 2500 files.
Fortec Ultra is a Pansat 2500 clone. Therefor there will be no more BINs.
At present on the Ultra you can see many of the "local channells" You can even get VOD but not PPV. You can get American Idol, DEal or No Deal, NBC, ABC news, old versionsof Oprah, fiends, steinfeld, etc. If you are satisfied with the limited programming available, then do nothing and enjoy.
Otherwise you will have no other option but to convert to Pansat 2700 using the jvvh files. Whilst the real pansat 2700 new BIN is already out (BIN 218) the jvvh version is still not out - I expect it will be out in a day or so.
The information on conversion is at
https://www.ecoustics.com/electronics/forum/home-video/389206.html
Username: Yousuf2221
Chicago, Il Usa
Pansat 2500 clone TRY OLD BIN 29Ot for 61.5 my still working
Username: Nydas
Post Number: 4228
DN version of 290T is working the same as 293T - in a limited way with the locals on 119W, ABC, NBC, PBS, etc. Even VOD is working. No PPV.
All of Echo 3 (61.5W) does not work with 290T or with 293T or 294T.
I have not been able to get a major part of 61.5W with 290T.
Username: Gonxggo
Post Number: 8
Nalin,
Thanks for the information. I will follow the link you posted and will convert FLU to 2700. Could you please post about new BIN for jwh once its available?
Thanks again for our prompt response.
Username: Perycles2005
Post Number: 37
Nalin, where can we check for updates to know when New Bin jwh is out for 2700 converted pansat clones
Username: Newtofta
Post Number: 157
I converted my FLU to a 2700 and done everything like i was supposed to but i still dont get all of my channels......my locals, ppv, po*n and other channels do not work.....i flashed with jvvh_208_1. Is there something else going on?
Username: Ill0_ill
Post Number: 15
New To FTA,
Now try putting the new pansat 2700 bin
X-87BL_071023_B75_218_api_1 and add the latest keys. Mine is working :-)
Username: Sccrskills
Post Number: 76
no u will kill your box if you put that bin in you have to wait for the jvh 218 bin to come out.
Username: Ill0_ill
Post Number: 16
OCT. 16, 2007 (active)
key (00)
2B D6 F6 C6 E5 B2 FA C8
79 F2 3A FF 10 4D 05 ED
Username: Ill0_ill
Post Number: 17
Sccrskills,
You are right, my reciver just went dead LOL !
Now i got to jtag right? :-(
Username: Huremkic
hi guys I have fortec star ultra I loaded new bin in and my reciver went blank. looks like there is no power,no # nothing , Did I do something wron and can I fix it and how
Username: Asharfi
Post Number: 1066
NEW TO FTA,
DO NOT LOAD THAT XBL BIN ... IT'S FOR ORIGINAL PANSAT 2700 ... IT WILL KILL YOUR BIX
Username: Nydas
Post Number: 4298
For those who have problems and failures, you can get the zipped file
2700 to 2500 via serial port.zip
This has the full kit to revert to Pansat 2500 clone status, and then start all over again to upgrade. It is available at amny sites, so please do not ask here. Just go and find it, unzip it, read the instructions and do it!!!.
Username: Tito71
Auburn, Al USA
Dear All, I have the FLU that rus under 218, I know that I have to convert it to 2700 to use the new JVVH218 So
1-Is fortec stars TB still the loader?
2-isb75_m still the boat file?
if any of the above has changed please let me know the name and location of each. Thanks for your help
Username: Devenw
MISIS
Post Number: 36
NALIN & FRIENDS
Please help me
I don`t know what happen, i convert my Lifetime Ultra to pansat 2700 it was working fine yesterday but when i check this morning no power on receiver, what should i do, please help me.
Thank you in advance
Username: Lklives
Post Number: 13161
http://www.dssrookie.com/forums/img-src-images-fortec-png-border-0-b-font-color- 0000ee-fortec-font-discussion-b/before-u-post-read-this-164561.html
Before U Post Read This!!!!!!
GUYZ THERE IS JVVH 218 BIN FILE AVAILABLE,TODAY IS FRIDAY OCT 26/07!!! SO PLZ STOP ASKING! READ BEOFRE U ASK UR QUESTION!!!!!!!!!!!!!
THERE WAS A NEW ECM OUT SO THATS IT WHY FORTEC WAS DOWN. >_> AS WE ALL NO IT HAS LITTLE TO NO SUPPORT SO WE HAD TO WAIT FOR EITHER CHANCYSAND OR JVVH TO MOD THE 218 PANSAT 2700 BIN! BLACK LIST HAS ALREADY SAID HE WILL NOT BE MAKING ANY NEW BINS FOR A WHILE SO STOP ASKING AND READ!!!!!! BE PATIENT!!!!!!!!!!!!!!
IF U WANT UR FLU TO WORK THE ONLY WAY RITE NOW IS TO CONVERT 2 PANSAT 2700 HERE ARE THE LINKS:
If u have FLU not cloned go here:
http://www.dssrookie.com/forums/b-fo...ed-149586.html
If U have a CLONE or OTHER PROBLEMS GO HERE:
http://www.dssrookie.com/forums/b-fo...-a-156890.html
THE LATEST FILE IS HERE:
http://www.dssrookie.com/forums/b-fo...re-164573.html
Username: Nydas
Post Number: 4305
Sharuk:
Using jvvh 218.
Today Whole of Echo 61.5 is OK, i.e. all Indian/Internationals are working.
Whole of Echo 110W is down. Nothing working - not even the locals.
