Username: Tylermoncrief Post Number: 106 Registered: May-04
Saturday, October 27, 2007 - 22:07 GMT Okay...Ive got a question I took the cover off the amplifier, and I hooked it up to the power,ground & remote So its running right And I hear a Ticking inside the amp! And I also look at the Protect like and that is Flashing Any clue what it could be?
Username: Van_man Boston South,
MA
Post Number: 2972 Registered: Mar-06
Saturday, October 27, 2007 - 22:16 GMT you raly need to find out with a meter if its getting 12-14 volts and that the ground is good. Is the car running when you test it?
Username: Tylermoncrief Post Number: 107 Registered: May-04
Saturday, October 27, 2007 - 23:29 GMT Yes Sir The Car Is Running.....And that volt meter says 14V
Username: Tylermoncrief Post Number: 108 Registered: May-04
Sunday, October 28, 2007 - 02:00 GMT ???
Username: Carguy Post Number: 6555 Registered: Nov-04
Monday, October 29, 2007 - 12:58 GMT Test your amp by itself first. See if it powers on without going into protection. If it doesn't then connect the rca from the HU. Also check the speaker wire strands. Make sure they're not shorting out. When an amp clicks like that, it's usually caused from signal overload or lack of power.
