Username: Kb1 Post Number: 22 Registered: Aug-07
Tuesday, October 30, 2007 - 17:33 GMT I converterd my 2500 clone to 2700 clone and uploaded the new bin. I scan and blind scan but only get internationl channel no matter what I do. I have two dishes one for loacl channel and one for internationl channel. So can some one tell me what should I do to get my local channel back. I know lots of people are have the same problem so let us help each other, Thanks
Username: Viruscauser Leesburg,
Georgia
Post Number: 319 Registered: Mar-07
Tuesday, October 30, 2007 - 18:02 GMT If you noted your antenna settings before you converted, reenter them. If you did not note your settings down, try these: Echo 7 - LNB Standard, Diseqc #1 Echo 8 - LND Standard, Diseqc #2 Echo 3 - LNB Standard, Diseqc #3 Don't worry about the skew etc and don't worry if a sat shows no quality. Enter those settings and scan again. See if that helps.
Username: Kb1 Post Number: 23 Registered: Aug-07
Tuesday, October 30, 2007 - 18:06 GMT Thankyou I will try this
Username: Ak2011 Post Number: 5 Registered: Oct-07
Thursday, November 01, 2007 - 00:14 GMT Okay I'm having the complete opposite problem. I can only get local channels but not international channels. I have tried doing a scan and blind on all Echo 7, 4, and 3 with all the Diseqc settings but am getting NO results. Please Please Help. It will be greatly appreciated. P.S. Is this a problem with the bin??
