Username: Cartier1 Post Number: 1297 Registered: Feb-07
Friday, October 26, 2007 - 20:52 GMT I DONT HAVE ONE BUT SOME SITES REPORT THAT THE BIN JVVH 218 KILLED THEIR REVEIVERS/
Username: Asharfi Post Number: 1135 Registered: Aug-06
Friday, October 26, 2007 - 20:56 GMT Working fine on FLUs
Username: Satgrl Post Number: 294 Registered: Oct-07
Friday, October 26, 2007 - 20:57 GMT on flus but what about on converted pansat 2700?
Username: Satscanners Beaversbush,
Sportsmans P...
Great White ...
Post Number: 4 Registered: Oct-07
Friday, October 26, 2007 - 20:57 GMT BOO !..... LOOK CARTIER .....SATSCANNER WAS RIGHT BEHIND YOU ! }
Username: Asharfi Post Number: 1136 Registered: Aug-06
Friday, October 26, 2007 - 21:02 GMT satgrl, It's working on Pansat 2500, too ... just converted my friend's ... as long as you load the correct way ... follow instrcution
Username: Satgrl Post Number: 296 Registered: Oct-07
Friday, October 26, 2007 - 21:03 GMT ok ill follow the instruction if i can even get past this part!!...i sstill got night rider i am currently loading factory bin
Username: Asharfi Post Number: 1137 Registered: Aug-06
Friday, October 26, 2007 - 21:06 GMT Try loading previous bin ...
Username: Machedonul Post Number: 250 Registered: Jul-06
Friday, October 26, 2007 - 21:06 GMT which of the sites has it? i have about 4 sites here under my favorites, but they apparently dont have it yet
Username: Shadow45 Mty,
Nuevo Leon
Mexico
Post Number: 109 Registered: Aug-07
Friday, October 26, 2007 - 21:08 GMT To anyone So this 218 file from the jeep guy is working ok on all converted receivers?. Please let me know , i have a lava3200 (2500 clon converted to 2700), any info will be greatly appreciated.
Username: Reggiep Post Number: 30 Registered: Sep-07
Friday, October 26, 2007 - 21:09 GMT Im trying to load this with the forctecstb loader and for some reason it wont flash. The screen pauses then it says connection failed. Ive unplugged and plugged my rs 232 wire in and out but it keeps doing the same thing. Do I have to get another loader?
Username: Reggiep Post Number: 31 Registered: Sep-07
Friday, October 26, 2007 - 21:10 GMT Am I doing something wrong here your suppose to load it as soon as you turn the power on from the back of the flu right?
