sheel neil i did answer your post you are posting the same qustion her is wat i can tell you im on bev all is good im using bin 152 but went on dssrookie and lots of others are having trouble you can try doing this factory reset then enable patch and when it rolls turn off auto roll this might help others are reporting that it started working after a couple of hours and others say it is working good if i were you i would go to dssrookie*com change*to a dot. and read what others are doing or wait till tommorow and there will be a nother bin to fix this one.
