Do the Pansat 2500s still work?
Username: Rolan
Post Number: 40
Are the Pansat 2500 receivers still working? I can't find bin files for them in FutureFTA... help!
Username: Vndpatel
Post Number: 256
if u cant find the bins then its done. and ya it is discontinued pansat 2500 will never have a new bin file.
Username: Dude123
Post Number: 1218
rohan
bob john is right pansat 2500 is discontinued but you can convert your 2500 into a pansat 2700 and use jwh bin files...
check this thread out --> Good Luck!
https://www.ecoustics.com/electronics/forum/home-video/397610.html
Username: Ember
please help where to get bin for pansat 2500 clone
Username: Dude123
Post Number: 1221
amber
can you read???? just read above what you just posted.....
Username: Rolan
Post Number: 41
Ok, I've got the instructions for the conversion. By the way, after I convert, will I always have to wait for jwh bin files? Or can I then use regular BL 2700 bins?
Username: Satgrl
Post Number: 105
u have to wait only for the jwh files which is not out yet do not load the 217 one cause the new PID is not in there ok..
