Lsot channels
Username: Shutterman11
Post Number: 9
I get some and not others on the
same bird and H frequency.
Have lost several in last
two days. Need to get them back.
I have dumped and rescanned with no
luck. Need the BC-VT game tonite.
Thanks
Username: Satgrl
Post Number: 66
well what receiver do u have?
Post Number: 10
pansat 2700
Username: Satgrl
Post Number: 87
well if u have read dish network has a new ECM out ...and the provider ID is diffrent its not 0101 no more its 0106 u cannot change it maunally u need to load the new bin into it...im not sure if thats out yet but..you should try looking for the one that is posted with a new date!!
Post Number: 11
Thanks,
but I am a total novice to this.
What does ECM mean, where would I
find it?
Thanks for patience.
Username: Satgrl
Post Number: 98
u will find it in the new bin it is the new settings for dish network.....i nee d help to setting my 2700a but no one will help i want to know if this is the right bin that i got from totalfta*net....do i have to do b-75 upgrade anybodyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
greeny
Super Moderator
Rep Points: 51
X-87BL_071023_B75_218_api_1.zip
newest 2700 fix.
(TBL version 218)X-87BL_071023_B75_218 Dish/Bev Bug Fixed
