Do anyone know how to program an FTA receiver by "KING"
Username: Tapeman
New York City in-HD, NY
Post Number: 1666
This is a true FTA question
Do anyone know how to program an FTA receiver?
I have a VU-Sat
As yo do factory default yo loose all your channel lineup settings.
If I want to save my lineup
What procedure do I need?
The manual that it came with was incredibly unhelpful
I know it can be done via rs232 or null cable
But how to do it, anyone?
King
Username: Dr_dss
Post Number: 71
Get and Load Channel Master,then READ FROM STB, now the channel master starting to down load the channel list, wait til it complete, then SAVE AS.... Now you have save a Full dump of you channel list.
Username: Dimwitt
Post Number: 161
or
TO SAVE CHANNEL INFO:
Power "ON" STB
MENU
INSTALLATION
RECEIVER UPGRADE
CHANNEL
Open LOADER2 in your PC
Click STB --> to --> PC
Data will automatically move from the STB to the PC and be stored as "chaninfo.cha" usually in
your Loader2 directory
Username: Tapeman
Post Number: 1667
Thank yo Dr. DSS and Tooter
I got loader2 I'll try it tonight
It can save a great deal of time deleting unwanted channels etc.
Username: Tapeman
Post Number: 1680
Actually what I found on VU-Sat website:
OSDEdit 1.6 - Channel Editor for (Plat and Xtreme)
ODSEdit4000_USA_v01082 (BIN)
- Support Favorite Channel Edit
- Support Channel Move Function
- Export Channel to CSV (Excel File Format) (Ver 1.2)
- Support Positioner Model (ODS 2000FP & CIP)
- Uploading/Downloading Main S/W channel & Satellite information between STB & PC
- Editing Channel & Satellite Information
(i.e. factory pre-setting of all the satellite & transponders information. In the PC its file is displayed *.SAT
*.PCH: Preset Channel or Programmed Channel. If yo execute the Facory Default, this channel is restored.)
Requirement
RS232 9 pin female connectors (Pin 2,3,5)
I got all the above from:
[link removed]
[link removed]
Did anyone try any of these procedures?
