Juan Cavazos plz help
Username: Bant07
Post Number: 18
since the provider ID has changed and i have pansat 2500A will it never get fixed my only choice is to convert....MY other question is i have viewsat extreme how do i input 0106 for provider ID can u please give me FULL instructions..do i have to load a bin first???please help i really appreciate it i will be waitin thanks...:-(
Username: Silver1123
Mexico, DF Mexico
Post Number: 304
Banti, as far as Pansat 2500 I heard there are no support for new bins. My advice to you is to look around these posts for shared experiences from different users that have converted, I have seen good and bad experiences.
As far as Viewsat, check here for a video tutorial
http://ftabins.net/showthread.php?t=733
Username: Bant07
Post Number: 21
nope it doesint say how to change the provider ID
Mexico, DF Mexico
Post Number: 308
You cant change the provider ID manually.
You need to install a new bin into your box.
Username: Rtap
FL
Post Number: 705
banti the new bins will take care off the new provider.
Username: Bant07
Post Number: 23
oh yes now i understand!!!!...ok so if i have pansat 2500A i would never be able to install the new bin right cause there are none ...so the only choice i have is to convert the receiver to a 2700A ok i understand!!...so is the new bin out for the one that is converted to a 2700a the one with the NEW provider ID? thanksssssssssss
Mexico, DF Mexico
Post Number: 309
Yes Banti, the new bin, when released, will have two sets of keys, the main ones dubbed as 101 and the new ones, dubbed as 106.
Now we have to wait. In the past, tbe bins were released between two or three days after the ECM, Electronic Counter Measure, that Dish sent.
