Kenwood amp
Username: M0nkeyman692
Post Number: 375
i was wondering if i could put bigger fuses in my kac9152d kenwood. because they are rated for 1 ohm stable but whenever i run it at 1 ohm it blows a fuse so i was wondering if i put a slightly larger fuse in it could it work without ruining the amp?
Username: Cblaze
Tn Us
Post Number: 251
somebody had a problem with there kenwood amp running at 1 0hm
Username: 420alldaylong
Post Number: 2785
I would not mess with the fuses they are that rating for a reason. Are you sure everything is wired right(ohm load)and is your gain set right.
Username: Jtown
ATX, Texas
Post Number: 562
NEVER get a bigger fuse. It's there for protection purposes.
Username: Nd4spd18
Northwest PA
Post Number: 3538
DO NOT EVER install a fuse bigger than what is specified. That would defeat the purpose of the fuse.
Kenwood amps are crap, and that model has been known to have problems at 1 ohm. My advice, you need a new amp.
Username: Van_man
Boston South, MA
Post Number: 2945
that amp should have 2 30 amp fuses. If its blowing them, then you may have a amp problem. Re check the ground wire. That amp should handle a 1 ohm load.
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1787
im the one who installed the amp for him. the ground has no resistence so its alright. it does have 2 30 amp fuses. its getting 14 volts of power. all hu settings correct.
the amp is rated like so:
4ohm-500rms
2ohm-900rms
1ohm-900rms
see that doesnt make any sence. it makes 900rms at 2 and 1ohm ive heard people having problems at 1ohm. shouldnt it have more power at 1 then 2ohms.
i just think kenwood is full of bs saying its 1ohm stable and its not really. the amp worked fine under a 2ohm load.
Username: Van_man
Boston South, MA
Post Number: 2946
They dont like to run at 1 ohm. I had my X811D worked on, and it ran fine at 1 ohm. Just beefed up the solder lines going to and from the power supply, and also replaced some resisters and caps inside with beefier ones from an old TV. But it shouldnt blow fuses, it should just go into protect if it dont like the 1 ohm, Most problem problem with those are the power supplies. Kenwood suggest there may be a short in the speaker wires, or the volume is too high.
Username: Snarl2004
Post Number: 1788
the stereo goes to 62 and the fuses blow around 35. i really dont think its worth it to put that much time and effort into it.
Username: Van_man
Boston South, MA
Post Number: 2947
agreed. Use it at 2 ohms, or ditch it.
Sox 2-0
Username: Snarl2004
Post Number: 1789
i go with ditch it :-)
Username: Cblaze
Tn Us
Post Number: 256
ya kenwood is ga y,i had the amp u got its the kac9103.i ran it @ 2 ohms,blew it with some old rockford fosgate 150 rms 15 inch subs on it,and took it back and got another and it wouldnt even power on,im with ditch it
