HElp with Pansat 2700 4 newbie
Username: Miamihitman09
Post Number: 7
Hello i get to signal at all on my Pansat 2700. In the Antenna Setup i go to echo 8.10/ku, I have 37% of level and no quality at all. . I uploaded the bin X-87bl api:75-2.13_Eubx Boot ver: 75 12 sep 2007.Can anyone help. I am a newbie. thanks to all
Username: Rtap
FL
Post Number: 697
the current file is X-87BL_071009_B75_217_api.zip
the problem with your signal might be your switch if any.check all your connection.
bin available at.http://ftabins.net/showthread.php?t=9846
good luck.
Post Number: 8
Thanks will need it..
Username: Nydas
Post Number: 4186
Eric garica : The 217 BIN WILL NOT WORK. You need BIN 218. It works only on genuine Pansat 2700.
