Converting 2500 clone
Username: Rookie1bc
which files should i use to convert to 2700, should i use the fortec files or the 2500 files to convert a 2500 clone to 2700? thanks.
Username: Whoami
Post Number: 50
this link will take you to the file you need to do the conversion
http://ftasolutions.com/forums/showthread.php?t=599
Username: Rookie1bc
i already have the files, i only need to know which ones to use for my clone. should i use fortec conversion files OR 2500 conversion files??????
Username: Whoami
Post Number: 53
Username: Satgrl
Post Number: 41
it depends do u have a 2500 clone or a fortec?
Username: Rookie1bc
i have 2500 clone.
Username: Satgrl
Post Number: 42
ok then u use the files that says 2500 but make sure its for clone safe
Username: Kb1
how do you know which file is clone safe
Username: Satgrl
Post Number: 47
its going to say NOT FOR CLONES or CLONE SAFE!!!
Username: Kb1
Is there any other source where we can get clone safe file the about like don't tell weatehr it is clone safe or not
Also what will I do once I converted 2005 clone to 2700 do I have to upload the new bin if yes where am I going to get that bin and what bin #
Thank you for you help inadvace
