Problem with 119
Username: Dghumman
Ontario Canada
Post Number: 113
I have satellite 110 and 119 on the same dish it was working fine untill few days ago but now 119 is not working.
i have signal strength of 76 and quality of 86 for 110 but for 119 i have signal strength of 60 and quality is 0.
i tried adjusting the satellite but nothing change do i need to change the lnb.
my receiver is viewsat ultra.
please help
Username: Tapeman
New York City in-HD, NY
Post Number: 1664
If I have to guess I will say yo damaged your DISEqC sw
If yo want to know exactly what is wrong then
List all your hardware: Receiver, LNB type, DISEqC sw, antenna settings etc.
I will get yo up in few minutes:
List:
Username: Dghumman
Ontario Canada
Post Number: 114
i have 2 recivers and i cant recive 119 on both and i just changed my diseqc sw yesterday
i have viewsat ultra and extreme
i have digiwave lnb
i cannot see 119 at all on both the receivers
Username: Lklives
Post Number: 13005
could be dish alignment, if dish 119 has moved even slightly by wind etc....or LNB...or cable from 119 LNB...or connections...or switch...etc....switches ($5) are most common problem and go bad easily, and surely if U changed it, but never unplugged the receiver..also recheck the antenna settings in both receivers..
Username: Dghumman
Ontario Canada
Post Number: 115
thanks lk for the info, i have changed the switches now i have cheita switches, as i have mentioned earlier i have 119 and 110 on one dish and i can receive 110 very good and the signal strength is 76 and quality is 86.
if the dish had moved then i would not get 110 also, i might be wrong so please tell me what to do, should i try changing the lnb or cable please advice
Username: Lklives
Post Number: 13022
U have to try 1 thing at a time...process of elimination...start with the easiest things...like, changing channels on the 119, rechecking antenna receiver settings, rebooting the receiver, then cable connections, then replacing the switch again, then replacing the 119 cable from LNB 119, then a slight dish adjustment, then LNB replacement....but u will likely find the solution very soon..
Username: Dishlover
Toronto, Ontario Canad
Post Number: 40
How can I add a channel like Zee sports. I have clone 2500. Thanks
Username: Rtap
FL
Post Number: 695
follow this link tamara.good luck
https://www.ecoustics.com/electronics/forum/home-video/392254.html
Username: Dishlover
Post Number: 41
Thanks RTAP is it possible to know how to add just single channel instead of sacnning to whole bunch of channels by default scanning. Much appreciated.
Regards
Username: Rtap
FL
Post Number: 696
try scanning the tp for that channel.
Username: Dishlover
Post Number: 42
OK will do thanks
