Can you wire 2 amps to one sub?
Username: Jman223
Post Number: 25
This may be a dumb question but i dont know the answer, can you wire two amps to one 15 inch sub?
Thanks
Username: Rovin
4 10 Pioneer...
Post Number: 12398
if the 2 amps are made to be 'strappable' then yes - both must be the same exact model though .....
Username: Jman223
Post Number: 28
ok thanks
Username: Rovin
4 10 Pioneer...
Post Number: 12401
it must state its strappable though - u just cant atke any 2 similar amps & strap them ....personally i rather just use 1 big amp instead ......
Username: Glasswolf
Wisteria, Lane USA
Post Number: 12076
I can wire 8 amps to one sub, it I strap them into pairs and use a quad coil sub.
Username: Rovin
4 10 Pioneer...
Post Number: 12410
^^^show-off ....
