Bronze Member Username: JryevolsLittle rock, Arkansas USA Post Number: 40 Registered: Mar-07 | Good Evening I have loaded 110 - 119 and found and loaded 61.5 , however it is mainly International channels. Are there any other birds that I can get with Pansat 3500sd that has more American channels not shown on 110-119 |
Platinum Member Username: LklivesPost Number: 12783 Registered: Jan-06 | 105..121..129...148 go to www.lyngsat.com ...check it out yourself.. |
Gold Member Username: NydasPost Number: 4001 Registered: Jun-06 | 148W is the same as 61.5W. LK does not know that people who can scan 61.5W will not be able to access 148W. She says things like that whether she is drunk or sober. Globecast is a good alternative, but it also has a lot of international channels. |
New member Username: Mj99AB Canada Post Number: 7 Registered: Sep-07 | Nalin/LK I have ariza700 Got twoo 18" dishes for 110 and 148. Basically i want to get zee sports which is on 119. Can i use 110 dish to get 119? I read poor mans dish but thats for different dish, Is that true? OR can i move my 110 dish and get 119 (replacing 110) Will i need to do anything else for that?? Thank you very much for your help. |
Gold Member Username: NydasPost Number: 4002 Registered: Jun-06 | ZEE Sports also known as ZEESA is on 61.5W which is similar to 148W in the West. If you already are scanning 148W, just do a Blind scan again. |
New member Username: Mj99AB Canada Post Number: 8 Registered: Sep-07 | thanks Nalin I will try that!! |
Gold Member Username: Dude123Post Number: 1209 Registered: Jul-06 | 148 doesn't have Zee Sports though, just thought I bring that point up, but it is available on 61.5 |
Platinum Member Username: LklivesPost Number: 12793 Registered: Jan-06 | Again nalin posts BOGUS info....LMAO! |
Gold Member Username: NydasPost Number: 4009 Registered: Jun-06 | And LK has a receiver 5 miles in the sky to look at latitude 148W and 61.5W at the same time. Ignorant fool! You sure are high! |
Platinum Member Username: LklivesPost Number: 12798 Registered: Jan-06 | Learn to read ...I never said that...U DID!....LMAO and U advised to scan the 148 for a channel that it doesn't even have, as The ONE pointed out!....LMAO |
New member Username: Mj99AB Canada Post Number: 10 Registered: Sep-07 | now i am sandwiched here!! let me know the solution guys i wanna watch next match,,, btw i did scans on 148 and could not get zsa. anyway hope u guys will help me out here... |
Bronze Member Username: GastrognomePost Number: 66 Registered: Dec-06 | If you have 119, scan transponder 12516. |
Bronze Member Username: Mj99AB Canada Post Number: 11 Registered: Sep-07 | I dont have 119, i got 110 and 148. My Q is can i change 110 to 119? how?? |
Bronze Member Username: GastrognomePost Number: 67 Registered: Dec-06 | yes, re aim it. |
Bronze Member Username: GastrognomePost Number: 68 Registered: Dec-06 | don't forget to do your antenna settings. |
Bronze Member Username: Mj99AB Canada Post Number: 12 Registered: Sep-07 | Gastro i dont know that Whats it? |
Platinum Member Username: LklivesPost Number: 12809 Registered: Jan-06 | Mj...listen to gastro...NOT nalin!...gastro is setting U straight! |
Gold Member Username: Dude123Post Number: 1211 Registered: Jul-06 | Mj99, I told you earlier its only avalable on 61.5 and 119 channel 576...if you don't have either of those you wont get that channel its simple as that. |
Bronze Member Username: GastrognomePost Number: 69 Registered: Dec-06 | go into your menu and you have to select echo 7(119)and assign diseqc port and lnb type. if you are moving the dish use the same settings that you used for echo8,10 (110) |
Bronze Member Username: Mj99AB Canada Post Number: 13 Registered: Sep-07 | Gastro this is what i found looks like there is not much diff btw two positions,,thanks i will try this also which antenna settings?? Sorry to ask simple Q but i have never touched dish before man.. LK thanks i am reading some stuff u and looks like u r master of all this stuff..appreciate whoever helps thanks... Your Location Satellite Data Dish Setup Data Latitude: 51.083° Longitude: -114.083° Name: 110.0W Echostar 8, 10 Distance: 38492km Elevation:31.4° Azimuth: 174.8° LNB skew: -3.3° ------------------------------------------------- Your Location Satellite Data Dish Setup Data Latitude: 51.083° Longitude: -114.083° Name: 119.0W Echostar 7, Amc16 Distance: 38497km Elevation:31.3° Azimuth: 186.3° LNB skew: 4.0° |
Silver Member Username: RtapFL Post Number: 601 Registered: Jan-07 | mj99 you need to read alot. when gastro says realign your dish.if your dish is pointing at 110 to get 119 you need to move your 9 degress.these links will help understand about dishes. Satellite Finders (Look Angle Calculators) ------------------------------------------------- http://www3.telus.net/rampage/skew.htm (Dish 500 support) http://www.remotesat.com/lookangle.htm |
Bronze Member Username: Mj99AB Canada Post Number: 14 Registered: Sep-07 | The One thanks,,, i know that man thats why asking how to move from 110 to 119. Gastro thanks lot.. |
Bronze Member Username: Mj99AB Canada Post Number: 15 Registered: Sep-07 | RTAP i will do that thanks...was just confused bit |
Gold Member Username: NydasPost Number: 4014 Registered: Jun-06 | ZEESA: Channell 576 Was originally launched on 110W and 61.5W. Now it is still on 61.5W but NOT on 110W. It is on 119W on Transponder 21, the next planned transponder is in 148w. LK: You do not know cricket, not watch it, have no idea what it is all about but have to come here to keep on harrassing me. If this does not stop, I will have to retaliate. |
Silver Member Username: RtapFL Post Number: 602 Registered: Jan-07 | guys chill a little bit.take my advice and use this medicine and you two might just get along. RLMAO |
Silver Member Username: KingusamaPost Number: 403 Registered: May-06 | there are varous satellites as posted by LK above... it really depends on your favourites... i would recommend doing a bit of research about the channels on them... |
Platinum Member Username: LklivesPost Number: 12813 Registered: Jan-06 | Don't tell me to chill out...I can dislike nalin, if i want to...she is BOGUS and does NO good here...U people keep complaining about me everytime I am exposing nalin's BOGUS incorrect info (that sometime kills receivers, like last weeks postings of hers), and then tell me to chill... well then I may just sit back and watch all of U screw up all your receivers...U can't have it BOTH ways...use me when your in trouble, then complain about me when I dislike someone who is BOGUS!...either U are a friend or NOT!... |
Silver Member Username: RtapFL Post Number: 614 Registered: Jan-07 | LK don't misunderstand me.you know i dislike nalin. i will never listen to her advice,and i've backed you up not because i'm a aass kisser but because you know your shhitt.the reason why i say chill out is because thinking or speaking to nalin is a waste of time.the people here who want to take advice from nalin will learn the hardway. |
Platinum Member Username: LklivesPost Number: 12816 Registered: Jan-06 | Like U said , 70% here are newbies...they don't know any better, so they listen to nalin...and all of U allow her BOGUS postings, which has run off many good people here ... Instead of ignoring her which only solidifies her existence here, especially towards the newbies..U should be joining me and exposing her BOGUS WRONGFUL DAMAGING postings!...then maybe we might be able to keep some good people here, and stop newbies from killer their receivers, or spending weeks on a simple 10 minute project.. Its not my nature to "rollover" and play dead, when somebody is being hurt daily because of an idiot like nalin, posting CRAP , to ONLY satisfy her ego, lack of knowledge, and no other site will allow her to post at!...for example her recent ban from dsrookie...and I know of at least 10 other sites, that she would be banned immediately...except here...cause U people allow it here, and rollover! |
Silver Member Username: RtapFL Post Number: 615 Registered: Jan-07 | lk i respect you and your knowledge.but i am not rolling over. |
Bronze Member Username: JryevolsLittle rock, Arkansas USA Post Number: 41 Registered: Mar-07 | Thank you all for responding to my question. I want to say that since I have used this site that LK has been awesome in his/her knowledge of the systems. This person has never led mewrong and all...I mean all answers have been perfect. Say what you wish , but I know that when I have a question answered by LK , I can trust the results. All of us appreciate your input LK and without you we might have as well placed out equipment in the garage. Thanks for being there |
New member Username: Desiguy1981Post Number: 1 Registered: Oct-07 | do any1 know when they will launch this channel on sat 148? thanx |
Silver Member Username: Impala1977Post Number: 169 Registered: Apr-06 | hey guys since the topic is sats does anyone know where i can find african channels on ku band or c band. |
