One 15" kicker L7
Username: Murderball
One 15" kicker L7 2ohm need suggestions on an amp.
Username: Ctmike
Ct.
Post Number: 5107
need a budget.
like 400 to around 600
Username: Imi4tth3w
San Antonio, Texas USA
Post Number: 77
i would say the zx 1000.1 would be perfect. i think you can get those for 300 refurb but if you have the budget to go higher there are a whole lot of better amps out there that i don't know of to suggest maybe others would know? ported box right?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4906
i don't think that's a good choice cuz he needs a 1 ohm stable amp, maybe a kicker 1200.1 will do the work for you
Username: Ctmike
Ct.
Post Number: 5155
sundown sae1000d.
Username: Van_man
Boston South, MA
Post Number: 2858
MMats D1500.1
Memphis MC100D
Kicker SX 1250.1
Username: Somedonniedude
Post Number: 238
Is that loaded in a kicker brand box? If so does it say 2 ohm impendance on the terminal cup? Otherwise im assuming your sub is dual 2 ohm.
Username: Krunk666
kicker KX850.2
850 watts @ 4 ohms bridged
This is what i have great amp with my 15 in ported box flexes the roof on my car, but as long as the sunroof doesn't stop working its kool
Username: Cblaze
Tn Us
Post Number: 84
us amps merlin md1d about 5 0r 600 but are nice
Username: Crxguy88
Post Number: 9
can you use that kicker zx2500.1 amp on the 15 in kicker l7?
Username: Drant19
TX
Post Number: 44
"can you use that kicker zx2500.1 amp on the 15 in kicker l7?"
yes if you set the gains correctly.. plus plenty of power if you choose to upgrade later
Username: 420alldaylong
Post Number: 2840
Sundown SAZ-1500D
Rockford T10001bd
Username: Crxguy88
Post Number: 10
where would i set the gain at then abarca?
Username: Drant19
TX
Post Number: 47
if your new to car audio, i would take it to an audio shop and have them set the gains. that sub needs to be broken in for a few before you can really push it hard.
Username: Nd4spd18
Northwest PA
Post Number: 3630
How to set the gain:
http://www.subwoofertools.com/forum/setgain.asp
Enter the number of watts you want the amp to put out, not necessarily the most it can do in your case.
