Dish network setup
Username: Cusumano3231
Post Number: 17
If one had an account w/ dish network could one just replace the dn reciever with a fta receiver to get the fta channels?
Username: Lklives
Post Number: 13006
It depends on the LNB's, dish type, and switches that DN has installed...and which FTA receiver U want to use..usually a swap is OK, but sometimes U may need to make changes in switches, cable config, and FTA type or LNB type....its NOT always just a simple Plug N Play swap!
Username: Rtap
FL
Post Number: 692
the dish family normally install the three lnb dish.if so will not be able to get 110 or 119 together.
