FLU (10/23/2007) DN down, Keys changed?
Username: Tscon
Everything was fine on 293T_api.bin (OLD)
till recently, everything just went down ("Bad or scrambled channels")
Key doesn't roll? or anything else has been
change? Or it's just me? (local weather?)
Anyone can confirm??
Thanks.
Username: Bant07
this is happening to everyoneeee!!!!!! please help
Username: Silver1123
Mexico, DF Mexico
Post Number: 287
Install newest bins as they become available, depending on your equipment.
Username: Tscon
Post Number: 8
"Install newest bins as they become available"
What are you smoking, dude? I'm saying KEY seems
doesn't change and bin stop working? Never happens
like that. Either they change everything or they don't..
Anybody else more sober?
Username: Kingusama
Post Number: 423
visit www.ftasolutions.blogspot.com
Username: Tscon
Post Number: 9
"visit www.ftasolutions.blogspot.com"
What? Common now!!! Anybody still watching DN
right now? I don't see that KEY changed! Must be
something else?
Username: Bant07
Post Number: 7
I KNOW RIGHT!!! I DONT SEE THE KEY CHANGE !!!!
Username: Tscon
Post Number: 17
ANYONE STILL SUPPORTING FLU ?
Thanks!
Username: Asharfi
Post Number: 956
Vasil Bikov ,
I'll help you out with the Fortec STAR Lifetime Ultra receivers. Right now, they are all down, right? The converted (FlU - Pansat 2700) receivers are down, too. TBL has released a new bin for Pansat 2700 receivers 1 hour ago. All the converted FLUs will have their fix in 2 - 4 hours because now JVVH will mod the latest Pansat 2700 bin so it can work on the converted FLUs. Now, for the FLUs that are using "T" bins, such as bin 294T, etc, I don't think there's gonna be any fix for those receivers. Like LK said, they are all "dinosaur", which means they're dying and the coders are NOT supporting those receivers. You should convert your FLU to a Pansat 2700 and then use bins by JVVH.
Username: Lklives
Post Number: 13033
Listen...a NEW special Dishnet Idea key 0106 has been introduced in the data stream which affected ESPN and some other channels last nite...then it spread to other DN channels...Bev is fine...so U need to upload a new bin released today or tomorrow which incoporated this new DN provider Idea keys 0101 ....its that simple!
Username: The_devil
Post Number: 14
Can anyone tell how to upload bin for captive works 600 premium step by step. Tried going on ftatalk but it doe sent work
