Username: O0airjordan120o MN
US
Post Number: 134 Registered: Sep-07
Tuesday, October 16, 2007 - 23:48 GMT i think im going to buy an 18 inch Fi BTL and power it at 1500 watts until i get a new alt. to put into it then power it at 2000. im going to put it into a 5 ft3 box ported to 33hz. wat do you think?
Username: Ctmike Ct.
Post Number: 5343 Registered: Feb-06
Tuesday, October 16, 2007 - 23:51 GMT i'd give it more power. if that's what you plan on giving it, i'd go with a bl with the bp options.
US
Post Number: 135 Registered: Sep-07
Tuesday, October 16, 2007 - 23:52 GMT also i noticed they have quite a few options on the site... which ones should i go with?
US
Post Number: 136 Registered: Sep-07
Tuesday, October 16, 2007 - 23:57 GMT i want to power it at 2000. it will only be 1500 untill i get a new alt.
Username: 420alldaylong Post Number: 2740 Registered: Sep-06
Wednesday, October 17, 2007 - 00:06 GMT Nick A fully loaded Fi BL 18" will shine on the power you mentioned above. ctmike I don't think the Fi BL have the bp options.
Username: Adddisorder Palm Beach,
Florida
Post Number: 5321 Registered: Jan-06
Wednesday, October 17, 2007 - 00:15 GMT nick 1500 to 2k isnt much of an upgrade, only 25%. also 1.5k on a stock alot is ALOT of current. and 2k isnt much for a btl.
Username: Hurricanebr1an Western Burbs of Chicago,
IL
Usa
Post Number: 177 Registered: Sep-07
Tuesday, October 16, 2007 - 22:21 GMT "ctmike I don't think the Fi BL have the bp options." yuh the option isnt listed, but could it be special ordered perhaps?
US
Post Number: 137 Registered: Sep-07
Tuesday, October 16, 2007 - 22:46 GMT ya its not much power but thats not guna make a difference is it? i want the BTL so i can have room to expand. and i only want to power it to RMS cus i dont want to blow nothin.
Username: Tatonka -[Team Audib...
Post Number: 965 Registered: Mar-07
Wednesday, October 17, 2007 - 00:32 GMT Go for it Nick. But if it doesn't satisfy you, add more power
