Looking for an amp
Username: Moondogg1212
Post Number: 116
whats up everyone. its been a while since ive been on but here goes. i'm looking for a amp that will give me 600-800RMS @ 4ohm. some names and prices would be much appreciated, thanks.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4947
600-800w rms at 4 ohms is kinda expensive, post voice coil config of your subs and we'll help you out, also your budget.
Username: Thunderb
Post Number: 53
Brian we really need to know a couple more things about the amp you want.
Is it for subs or mids & highs ? ( so we can decide amplifier class )
What ohm load do you plan on using it in ? ( high current or high power)
Do you need 2-4-6 channels? ( pushing just subs or the whole system)
Just a little more detail will help out greatly.
Post Number: 117
i need a class-d that will give me around 600-800 @ 4ohm. i have (2) single 8ohm W3.
Post Number: 118
not much for a budget right now just looking for prices. thanks.
Username: Rovin
4 10 Pioneer...
Post Number: 12288
IMO u should get a 2chan amp & bridge it ......
Username: Thunderb
Post Number: 63
"IMO u should get a 2chan amp & bridge it ......"
I agree with Rovin . It would be cheaper for you to go with a class a/b amp that puts out 600-800 watts RMS @ 4 ohms than a class d amp that pushes 600-800 watts @ 4 ohms.
Username: Juliob
Post Number: 4953
rockford 8002 will work
Username: Somedonniedude
Post Number: 298
I have a rockford p6002, 600wrms @ 4ohms bridged. I saw a few birthsheets on these exact amps that said anywhere between about 690-730 actual wrms. can do $150 shipped. It has about 2 1/2 months of use on it.
Username: 420alldaylong
Post Number: 2727
Its there entry level amp but it will get the job done. If you think its putting out to much power turn the gain down and you will be fine.
http://www.millionbuy.com/usaxt16002.html
Username: Massiveaudio
Agreed-
