u have to be pointing to the right sat with the right information about the sat. exemple: some poeple they configure their receiver on echo9 while thinking on echo 7. even if the tp 's may be the same and you get channel but the guide u can not get it .
try to download the guide . and make sure of what i said. also make sure of seting your time correct.
