Thanks 2 da UPS guy
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1251
Okay look what the ups guy brought me today. Yes its a Mmats 2100.1. I installed it and Damn it made my sub come alive. It was twice as louder than what it was with the PPI 21400. Another thing that i love is the amp is really small. Upload
Username: Andrew571
Post Number: 1221
great amp right there!, installed pics!
Username: Loc_out
Post Number: 1254
I will get some tomorrow....
-apem
Post Number: 15418
nice. i can't wait to hear it. make sure you go to the car show tomorow.
mmats ftw!!! you got the baby brother of my amp. lol.
Username: Frkkevin
Post Number: 3751
i want my amps to come in :-(
Username: Loc_out
Post Number: 1256
what kind of amp and what sub???
Chad what time are you going to be there???
-apem
Post Number: 15420
i'll be there between 3-4 pm.
Username: Loc_out
Post Number: 1257
what time does it start???
Username: Frkkevin
Post Number: 3752
im waiting for my dd m1 and diamond d5 300.2 .. if you were asking me about the amps lol
Username: Bernymac
BME
Post Number: 3349
Starts at 3. I'll be there around 12-1pm so that I can get a good spot to park my car. I don't feel like being far away from my ride :-).
Username: Th3pwn3r
Post Number:...
Post Number: 5318
That amp is sexy.MMATS is th3 sh1t!
Username: Loc_out
Post Number: 1258
Thanks rob. hope it stop rainin berny and chad can you guys help me adjust my amp:-)????
-apem
Post Number: 15421
sure. but that amp is one of the easiest to adjust. it has no features. lol. its just a solid beast.
Username: Loc_out
Post Number: 1259
I notice it only have to nobs. But my mids sound like sh1t help me adujust it?
Username: Loc_out
Post Number: 1260
install pic oh an i need to clean up some of the wires. Upload
Username: Jtown
ATX, Texas
Post Number: 518
how much did it cost you?
Username: Loc_out
Post Number: 1265
I got it for 300 ebay.
Chad, berny thanks for the advice yesterday.
Username: Bernymac
BME
Post Number: 3352
only advice I can think about is the door pods? Do them, I wanna see how they look. That one where the guy just put the mdf speaker rings on the grill, he didn't even fiberglass it, he just straight out used duraglass on it. So it'll be easier than you think now since you don't even have to do any fiberglassing lol. Just spread out the duraglass and then sand it down! fosho. If you need more info just hit me up. my aim is mrbernymac.
Username: Extrmndor3
Post Number: 6985
yo lowlife nice amp man.. the only flaw im seeing is that i think i see some 4 gauge im i right??? if so upgrade it to atleasst 2 gauge or 0 gauge if you have 0 or 2 dissregard what i say but nice amp man.
Username: Somedonniedude
Post Number: 299
it looks like he has 2 running to the dist. block, then 4 to the amp, but that also could be 0 to dist. and 2 to amp i guess.
Username: Loc_out
Post Number: 1267
Zpeedy yes I do have some 4 gauge wires I plan on upgrading everything to a 0 gauge. I need some advice on how to do it. I'll a diagram an maybe you guys can help me out.
The door pods will be in soon that's my next project hope they come out good.
-apem
Post Number: 15449
hey did you disconnect the rear speaker like i told you?
Username: Loc_out
Post Number: 1268
NO sir i did not disconnect them but i did place them in the rear. Now i have the front rear option. Yes it does sound a lot better.
Username: Loc_out
Post Number: 1269
How does this look?Upload
Username: B3n07
Louisville, Ky USA
Post Number: 425
looks like a good plan i have mine ran with 2 gauage from battery to cap and the 2 from cap to dis and then from the dis i have 8 going to my amps
Username: Loc_out
Post Number: 1272
anyone else???
Username: Bernymac
BME
Post Number: 3361
Does your mmats amp have 0ga inputs? If it has 4ga inputs, use 4ga wire. If the amp needed 0ga it would of had 0ga inputs. So look into that. I know you have 2 amps, one for your sub and one for your components. I don't know if you have a fused distribution block or not, I would get one.
Username: Loc_out
Post Number: 1277
I think my mmats amp will only take a 4gauge but i will double check. No fise distribution block.
Username: Bernymac
BME
Post Number: 3365
If you wanna use 0ga for power and ground for the mmats amp, I would take a torch and some soldering wire, fill up the wire with soldering wire, then grind the wire down to 4ga. Or get the adapter for 0ga to 4ga.
