Little advice
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 676
plan on upgrading my amps. i have a 2002 chevy malibu with a 105a alt and im planning on running a kicker zx 200.4 and a jbl 1200.1. i want to use my stock electrical system.u guys think ill be good?
Post Number: 677
bump
Username: Loudon
Post Number: 1803
u might have alittle trouble ...
the jbl isnt exactly easy on an electrical .. i ran it on my jetta stock alt .. and i had alot of dimming ... with a kicker kx 100.2 ..
do big 3 .. upgrade ur batt ... be easy on the volume knob
Post Number: 678
true true... alright thanx for the help mike.
Username: Adddisorder
Palm Beach, Florida
Post Number: 5289
i am willing to say that you will be pushing it very close, i have the bp1200.1 too and while it is an excellent amp it loves current.
Post Number: 679
u think ill ruin my alt? or just a matter of dimming and ish?
Palm Beach, Florida
Post Number: 5291
dimming is voltage drop, even can happen with HO alts. not bad unless it starts to drop below your battery voltage. i couldnt even run that amp at 4ohm on my new 80 stock alt. now that i have a 180a it powers the amp fine at 1ohm, im even running another 500rms on top of that.
Username: Nd4spd18
Northwest PA
Post Number: 3379
I would not run that amp on a stock alt.
Post Number: 682
hmmm... alright thanx for the advice guys
