Mounting amp
Username: Quirky
SA, Texas
Post Number: 153
I don't have much space in the back of my car and need a place for my amp. my two locations are either mounted on the box or under the box (down-fire). I've been told the vibration can damage my amp if mounted on the box directly.
Is there a way i can prevent vibration to the amp by mounting something between the amp and the box?
Thanks,
Ben
Username: Andrew571
Post Number: 1225
rubber washers...MDF...foam material, anything that will logically absorb vibrations before reaching the amp.
Username: Quirky
SA, Texas
Post Number: 154
k, thanks Andrew.
Username: Nd4spd18
Northwest PA
Post Number: 3365
Where you mount it makes a difference also.
Go to this page and scroll down to the middle:
http://www.bcae1.com/amplfier.htm
Username: B3n07
Louisville, Ky USA
Post Number: 408
if you dont have to much room in trunk dont you have the back of your seats mount your amps there
