Silver Member Username: Santa_fePost Number: 253 Registered: Jul-07 | ok ...i have a spec that says it does 750 to 1 at 2 ohms.....anyone heard anything else??? I think i might be wrong with that...but why does the amp have two channels its says its a directed 1100d so why two channels?? And when setting the gain what channel do i use? |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5250 Registered: Jan-06 | it does have 2 channels just 4 terminals. its a mono block with 2 + and 2- terminals just use whichever ones you want they are wired in parallel internally. |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5251 Registered: Jan-06 | it DOESNT**** have 2 channels |
Silver Member Username: Santa_fePost Number: 254 Registered: Jul-07 | so it wont matter if i use the positive from one side and the negitiv form the other??? |
Silver Member Username: Santa_fePost Number: 255 Registered: Jul-07 | and can someone plzz hunt down some relaidble spce for this amp i have found three different sets of specs and am not sure what ones to use its a directed 1100d |
Gold Member Username: CenusOhio Post Number: 3635 Registered: Jan-05 | http://ampguts.realmofexcursion.com/DEI_1100d/ is that your amp? |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5262 Registered: Jan-06 | yeah it should do 1100@1ohm i belive. and yes just use any - + you want they are connected internally, it doesnt matter which ones you use at all, just hook the sub wires up the right way though. |
Silver Member Username: Santa_fePost Number: 256 Registered: Jul-07 | hey is there any way i can run two subs from a mono amp like this a result in a 4 ohm load??? Both the subs are 4 ohm sv....lol doing the install right now.... |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5264 Registered: Jan-06 | nope you cant run 4ohm load on amp with 2 4svc subs. only 2 or 8 |
Silver Member Username: Santa_fePost Number: 257 Registered: Jul-07 | thats what i thought okay |
Silver Member Username: Santa_fePost Number: 258 Registered: Jul-07 | will my stock alt be okay with that like 750 watts rms??? |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5267 Registered: Jan-06 | hard to say only real way to know is hook it up and watch the voltage at idle and with higher rpms. |
Silver Member Username: Tatonka-[Team Audib... Post Number: 956 Registered: Mar-07 | Yes it will Santa Fe |
Silver Member Username: Santa_fePost Number: 259 Registered: Jul-07 | how do i set the gains??? Where do i put the prongs on the DMM!!!! Im doing this as i get adive so plzz post fast lol |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 10523 Registered: Jun-06 | http://www.subwoofertools.com/forum/setgain.asp Might help. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 10524 Registered: Jun-06 | Use the tutorial. http://mobile.jlaudio.com/support_pages.php?page_id=143 |
Silver Member Username: Santa_fePost Number: 260 Registered: Jul-07 | ok what shall i tune the subs too 50 hz??? i think thats the normal right |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5268 Registered: Jan-06 | you mean what hz tone should you play then 50 would be fine. |
Silver Member Username: Santa_fePost Number: 261 Registered: Jul-07 | where can i get ones of thoes sweep |
Silver Member Username: Santa_fePost Number: 262 Registered: Jul-07 | bump |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3635 Registered: Jan-06 | That isn't his amp, this one is.. Ohhh wait that is mine... ![]() ![]() |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 10527 Registered: Jun-06 | ROE has a complete list. http://www.realmofexcursion.com/ Go to downloads and choose. |
Silver Member Username: Santa_fePost Number: 263 Registered: Jul-07 | what setting should my Dmm be on????? im gettin some weird numbers |
Silver Member Username: Santa_fePost Number: 264 Registered: Jul-07 | i need ones that are not mp3.... |
Gold Member Username: CenusOhio Post Number: 3637 Registered: Jan-05 | wow polo do you want a fvckin cookie? santa fe do you have any bass mekanik cd's? they useally have test tones on them. |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3636 Registered: Jan-06 | STFU Dustin, you F@g, lOl.. Hey if you need tones me up ...Polo30@ameritech.net I can create them at any frequency you need in any file format.Polo.. ![]() |
Gold Member Username: CenusOhio Post Number: 3641 Registered: Jan-05 | you only wish i was polo, ![]() |
Silver Member Username: Santa_fePost Number: 266 Registered: Jul-07 | no i got it guys thanx |
