Epicenter
Username: B3n07
Louisville, Ky USA
Post Number: 400
hey is anyone selling one i am looking to buy one and also how many amps can you run off one
Username: Joebruce
15 AQ HD3
Post Number: 1539
ebay usually has some good deals on used ones and i think the new ones on ebay are only $120 shipped. Also try ca.com. you can only hook up one amp from the Epicenter but if your amps are linkable then i would assume the Epicenter would work with both amps like that.
