New member Username: DirdyHilliard, Ohio Us Post Number: 1 Registered: Jul-07 | I recently updated my Itunes software, and went to go to use my ipod shuffle by adding some songs. My shuffle worked fine until i pluged it in and itunes told me it was corrupt. I go to restore my settings since i couldnt add or remove any songs and my ipod has a unknown error where the ipod can't be restored or it failed to restore. (1418) is the number or type of unknown error it says occurs. I tried restoring the ipod on two diffrent computers with no luck. Anyother ideas would help, thanks. |
New member Username: MymusicPost Number: 1 Registered: Jan-08 | Hey! I hope is not too late for giving you a hand with your iPod. You'll find a software that can give you a diagnose of your iPod and also fix the errors it has. check it out: http://www.copytrans.net/gettingstarteddoctor.php |
Platinum Member Username: Project6Post Number: 14177 Registered: Dec-03 | How much? Is there a money back guarantee if it fails to do what it claims to do or is there some sort of loophole/fine print that users need to read? |
