Bronze Member Username: Homeboi88Lexington , Kentucky United states Post Number: 75 Registered: Apr-07 | what farad capacitor would i need if im running to kicker zx1000.1 amps? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3425 Registered: Jul-06 | Don't need a capacitor, they don't help. |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 12067 Registered: Dec-03 | http://www.bcae1.com/capacitr.htm http://www.glasswolf.net/caraudio/capacitors.html http://www.glasswolf.net/caraudio/charging.html http://www.betteraudio.com/geolemon/newmain/battcapalt/ http://www.bcae1.com/charging.htm http://www.bcae1.com/chargin2.htm http://www.bcae1.com/battiso.htm http://www.glasswolf.net/caraudio/batteries.html http://www.the12volt.com/info/recwirsz.asp |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 5381 Registered: Jul-06 | They do help but only in certain situations. |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 12070 Registered: Dec-03 | they work well as a ripple filter, but since a capacitor's voltage follows the circuit voltage, they certainly don't help to keep voltage rails stiffened when the alternator is pushed beyond it's limit. |
Bronze Member Username: Homeboi88Lexington , Kentucky United states Post Number: 76 Registered: Apr-07 | is there a website where i can upgrade my alternator |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3460 Registered: Jul-06 | http://www.db-starter-alternator.com http://stores.ebay.com/Iraggi-Alternator-and-Electronics http://www.ohiogen.com/ |
