I have a Mits WD-65731 that is a year old. Now when I turn it on I get a msg that the tv will shut down and check the air flow. I have checked the lamp and it is not dirty. I have checked the airflow and it is OK. After it shuts down I can try it 3 or 4 times again and the TV will start working fine. Any suggestions?
Mitsubishi WD-65731 Error. I keep getting a msg that says tv will shut off and to check the air flow. I have done both. After repeated attempts TV will start working and work fine for a while. Anyone have any idea if this is hardware related?
