When i turn it up loud i notice that 1 of the ehqs make a banging type noise, like its hitting something. Anybody know what the problem might be. Maybe its flexing a little too much?
It's probably bottoming out.Maybe the tinsels are slapping or maybe it's distorting.There could be a lot of things going on there.Do you have it in a sealed box or is it ported?Are you giving the sub recommended power?Do you have the wires away from the moving parts?Try not to play it to the point of where it's making that sound because I'm sure it doesn't sound very good anyways so back off of the volume for a bit until you discover what the problem is.
