Need a bit of help plz...
Username: Dubmc23
Rapid City, SD USA
Post Number: 13
ok heres the deal i have my zx750.1 setup to my 15" kicker d4 2 ohm cvr and when i hook it up it only stays on for about 3 seconds with all settings way down...whats my problem?? oh and the wiring setup is 1 ohm stable...
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1983
Well first the zx750.1 is 2 ohm stable. Second, I'm really confused. You said "15" kicker d4 2 ohm cvr". d4 usually means dual 4. Are you sure it is a 2 ohm cvr?
Username: Dubmc23
Rapid City, SD USA
Post Number: 14
oops sry bout that...but im posative its a 2 ohm cvr...still confused?
Post Number: 1984
Then you need to wire it for a 4 ohm load. I mean you can wire d2 subs for a 1 ohm load but like I said that amp is 2 ohm stable.
Username: Dubmc23
Rapid City, SD USA
Post Number: 15
ok whoah wait im confused now lol...d4 means dvc right???
Post Number: 1985
d4 means 4 ohm dvc.
Username: Dubmc23
Rapid City, SD USA
Post Number: 16
ohh aight thanks...well does that explain y it keeps shutting down??
Username: Bernymac
BME
Post Number: 3338
do you have a dvc 4ohm sub wired down to 2ohms or do you have a dvc 2ohm sub wired down to 1ohm?
Username: Dubmc23
Rapid City, SD USA
Post Number: 18
dvc 2ohm wired to one ohm...is there another way i should wire it??
Username: Nd4spd18
Northwest PA
Post Number: 3305
With that amp, you have to wire the subs coils in series resulting in a 4 ohm total.
