2 dresults of the audioque 2.512 vs digital dsign 3512
Username: Insearchofbass
Post Number: 6673
The digial design 3512 hit 144.2 db at 700 rms at full set volume of 21 on the cd player and the audioque 2.5 12 hit 144.9 db at 19 volume out of 21 on the cd player (less than 700 rms)....from what we can tell the digital design 3512 could hit 1.5 db more or so given 1200 rms but ourstock battery and stock alternator 130 amp cant give enough to produce the 1200 rms out of the amp .....these results were in the exact same box port tuned to 54 hz but the audioque hit its spl below port tune (53 hz wierd) and the digital design did its best spl at 55 hz...so long story short if you dont have the charging to give a higher power handling sub you might want to think twice
